Thread: rev limit
04-05-2012, 03:59 PM #1
rev limit
right now my rev limiter is set at 6k rpms because my injectors are hitting 100% duty cycle at this rpm. New injectors are in the works and I was wondering what you guys would say a safe higher rpm would be. how fast are you guys spinning? dragonslayer 4" crank, callies "H" beams,diamond forged pistons,A.F.R 210cc heads with dual valve springs. the rotating assy. has been balanced twice.(once by texas speed again by my machine shop) I'm thinking 7500 rpm.
04-05-2012, 04:27 PM #2
04-05-2012, 04:30 PM #3Electrical Engineer
- Jul 2009
- North of the Motorcity
But I think you need to know your HP/ torque curves to know what you should be running the limiter at.
04-05-2012, 07:00 PM #4
KM is right, why spin the motor higher if it isnt making power/torque.
04-05-2012, 07:16 PM #5I like turtles
- Aug 2007
- Corn and Soybean fields
Depends on the peak and what kind of drop it sees after the peak.
04-06-2012, 02:33 AM #6
i meant that as a max obviously i would stop it when peak hp and tq were met :-) at what rpm do you think i will find the weakest link?
04-09-2012, 09:10 AM #7Electrical Engineer
- Jul 2009
The only way I know to figure that out is the hard way, which I'm sure you don't want to do. Or if another member happen to find out the hard way.
Would get your power curves, determine your shift points, and set the limited to ~200rpm higher. Unless, for track purposes, your an m6 and need to run the rest of a gear out instead of shifting because within 100ft (or whatever close distance) of the finish line.Last edited by KMdef9; 04-09-2012 at 09:16 AM.
WHP limit ??
By 2NDSLPSS in forum Internal EngineReplies: 8Last Post: 01-12-2012, 03:06 PM -
Question: new rev limit
By mark21742 in forum Computer & TuningReplies: 9Last Post: 01-22-2009, 09:00 PM -
$50 gas limit
By JonB in forum Almost Anything GoesReplies: 26Last Post: 06-22-2008, 06:02 PM -
What's the limit
By Phlash_riot in forum Almost Anything GoesReplies: 27Last Post: 12-07-2006, 09:40 PM -
LT1 and rev limit
By cnr2b1 in forum Firebird / WS6Replies: 2Last Post: 04-30-2006, 07:30 PM
