Results 1 to 10 of 10
Thread: new rev limit
    mercersburg pa
    hugger orange
    2004
    new rev limit
    I was wondering what I should set my rev limit and reset my WOT shift points to with my current mods. I'm using hptuners and have it tuned pretty close for now, but will eventually get a full pro dyno tune. the car has never been on a dyno so I wasn't sure if I am hitting the rev limiter way to early and leaving lots power untouched.
    also any estimates on rwhp?
    04 a4 GTO ls1
    calibrated SLP MAF, cold air/ram air, p&p tb, stock ls6 intake, ported & polished stock 241 heads, 220/224 .570/.580 112lsa cam, 918 comp springs, pacesetter lt's, 3" true duals with super 44's
    any help would be greatly appreciated!
    Member adam3566's Avatar
    Janesville,Wisconsin
    black Silver
    06 silverado/ 06 C6
    Quote Originally Posted by mark21742 View Post
    04 a4 GTO ls1
    What are you currently set at? Sounds like you got a decent setup, except I didn't notice any stall with an A4.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by adam3566 View Post
    I knew I'd forget something lol
    2,800 tci stall. full cutoff is set at 6,400 rpm now
    black Silver
    06 silverado/ 06 C6
    Kinda a small stall, is it your DD? Otherwise I would say 6200 would be perfect and from what I have read, it seems like a lot of guys with around your setup run 6100-6200 without a problem.
    mercersburg pa
    hugger orange
    2004
    yes I didn't want to go with too high a stall because I do drive it every day. I have had other cars with bigger stalls in them and they just weren't as friendly to drive around town......plus cops look at you quicker when you have to really rev it high to get rolling from a light lol
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    The Yank stalls (esp PYE) are very tight under flash which makes them feel much 'smaller' than many other brands. The TCI units that I have tuned on were pretty loose...
    I'd likely set your rev limiter at 6600 and depending on what I see on the dyno, shifting would be around 63-6400 most likely
    mercersburg pa
    hugger orange
    2004
    ok thanks Frost! im glad i took your advice on the cam, i think if i would have gotten any of the ones i was looking at at first they would have been too big and i wouldnt have been happy with them
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    over camming is rampant and encouraged in many cases by a lot of keyboard-racers. I have had more than one customer tell me what they want and then go wild on the cam when they thought their recommendation was too small only to swap them out later...
    I agree.....when I ordered my 228 they recommended the 233. I didn't want to spin the motor high and wanted it to have decent street manners so I stuck with the 228....glad I did.
    That being said I have been thinking about going a little bigger. I will most likely just add a little shot of spray instead.
    mercersburg pa
    hugger orange
    2004
    I figure one of these days I'll work on my 87 nissan pulsar and make it my daily driver, then go more wild on the goat when its my weekend toy
  1. rev limit
    By 383ls6 in forum General Help
    Last Post: 04-09-2012, 09:10 AM
  2. WHP limit ??
    By 2NDSLPSS in forum Internal Engine
    Last Post: 01-12-2012, 03:06 PM
  3. $50 gas limit
    By JonB in forum Almost Anything Goes
    Last Post: 06-22-2008, 06:02 PM
  4. What's the limit
    By Phlash_riot in forum Almost Anything Goes
    Last Post: 12-07-2006, 09:40 PM
  5. LT1 and rev limit
    By cnr2b1 in forum Firebird / WS6
    Last Post: 04-30-2006, 07:30 PM
