Thread: WHP limit ??
    Apr 2010
    hawaii
    2001 camaro ss
    WHP limit ??
    383 Ls1, callies compstar 4.00 crank, compstar H beam rods, arp 2000 rodbolts, wiseco forged pistons, arp headstuds & mainstuds. Ls9 head gaskets, clevite main and rod bearings, Boosted & wont be reving past 6800 rpms.
    Whats going to let go first, and at what WHP ? Or whats the max whp that this setup can handle SAFELY?
    Member 383ls6's Avatar
    Nov 2009
    dallas,texas
    2002 z/28
    I have a very similar setup that yielded 440rwhp/420rwtq and can spin it to 7000 rpms and hold it there unboosted though.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Naturally Aspirated...you won't touch the limit of the internals.
    I have the exact same brand internals in my 427 LS3, and the rods are the lowest rated part at about 900hp. If you go forced induction, I would be worried about the block long before the internals.
    Pittsburgh
    2008 Hummer H3
    If there's a 10-bolt rear under it that may go first..
    Stock 3800's can break them..
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    I have the same bottom end in my motor, put down 430whp and 428 wtq with stock heads. My rear let go in September. I now have a strange s60 under the car.
    Callies 383, Trick Flow 225, Rapid Motorsports Dominatior 2 X cam, ls6 ported oil pump,42lb injectors, FAST 92/92 , ASP underdrive pully, eletric water pump, Pacesetter LT's, Pacesetter ORY, Magnaflow catback, e-cutout, Yank SS 3600, Performabuilt stage 2 4l60e, Strange S60 ,4.10s, Detroit Truetrac, (UMI) - Adj. LCA, Adj. tunnel mount torque arm, Adj. panhard bar, Drag bar, subframe conectors, shock tower brace. 465rwhp-438rwtq [email protected].
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    As far as the enging goes I would say the bearings will let go first but that is with the spray. Other wise it is a strong combo. The other parts of the drivetrain will suffer first. 10 bolt reat, U-Joints and tranny components. I will say 430 rwhp is in the range without spray.
    Apr 2010
    hawaii
    2001 camaro ss
    Everything in the driveline will be replaced. Im going to go with a built 4l80e, better driveshaft& yokes, a 12 bolt, also better heads, dual walbros,60# injectors, FAST, CNC'd and heads .so im mostly worried about the bottomn end. I will be running a D1sc and want to put down 650 on the pumpgas street tune
    will I be stressing the the rods at all ? My invoice from tsp said they are 900 hp rods. Are they talking about at the flywheel ??? If so the 700+whp race gas tune I had in mind may be out the window w these rods. . .
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by 2NDSLPSS View Post
    I believe that is crank, but I'm sure they're rated for more hp, just not reported, so people stop short of the limit.
    Have you ordered the motor yet? If not, why not upgrade the rods?
    Apr 2010
    hawaii
    2001 camaro ss
    I have an ls1 engine out of my 00' SS. I ordered said rotating assembly because rep at tsp told me he would have no problem pushing this bottom end to 1000 whp but then it comes in with an invoice that says rods. . . 900hp I started researching. ( wrong order, I know !)
  1. rev limit
    By 383ls6 in forum General Help
    Last Post: 04-09-2012, 09:10 AM
  2. Question: new rev limit
    By mark21742 in forum Computer & Tuning
    Last Post: 01-22-2009, 09:00 PM
  3. $50 gas limit
    By JonB in forum Almost Anything Goes
    Last Post: 06-22-2008, 06:02 PM
  4. What's the limit
    By Phlash_riot in forum Almost Anything Goes
    Last Post: 12-07-2006, 09:40 PM
  5. LT1 and rev limit
    By cnr2b1 in forum Firebird / WS6
    Last Post: 04-30-2006, 07:30 PM
