Thread: Check Engine - MAF and A/C
04-01-2012, 09:40 AM #1Junior Member
- Sep 2005
- houston
Hey everyone
Check engine light came in my 04 GTO last week but everything seemed fine; I headed to Autozone yesterday and my A/C stopped blowing cold on the way. Guy checked it and came up with problems for the mass airflow sensor and AC clutch relay control circuit. For the MAF I had used a recharge kit for my K&N and I guess I used too much oil and the little filaments were covered with it. I just used a q-tip to clean it off. Wil this be enough to solve any issues there?
As far as the AC clutch relay control circuit has anyone had any problems with those? My ac has always blown cold and the weekend it gets up to 90 in Texas my ac stops working. Is this an easy/cheap part to replace or is it going to be an expensive hassle?
Thanks everyone for the help
04-01-2012, 02:47 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Get yourself some CRC MAF cleaner. Silver can. About ten bucks at your local parts store. Take the K&N and wrap in newspaper for a few hours if not overnight so the oil soaks into the paper. You'll be golden. Did you try switching or replacing the relay for your AC?
04-01-2012, 03:43 PM #3
^^^^ +1
04-01-2012, 07:23 PM #4
^^^^^^+2, be careful with the q-tip they can do a lot of damage, the maf cleaner it the best. What's crazy is the same thing happened to me 2 weeks ago cleaned my k&n and code came up for maf and ac, figured the oil from the k&n had done it's damage and cleaned everything up and the check engine light went out and the ac worked perfect, have no idea why both would be effected.
04-01-2012, 07:28 PM #5Junior Member
- Sep 2005
- houston
I switched the relay with the one for high beams. Lights worked with both the relays but the AC didn't. I bought some of the spray today and will try it out tomorrow. A little worried because when I used a q-tip the other day to clean off the filaments I wasn't very gentle at first and one of the filaments kind of bent out of place. I pushed it back and nothing tore off or anything, but I hope I didnt trash my MAF.
04-01-2012, 07:41 PM #6
04-02-2012, 06:19 PM #7Junior Member
- Sep 2005
- houston
I used the cleaner on the MAF today. Unfortunately I may have other issues. When I had the codes read we opened the hood and the tube connecting to the K&N filter was disconnected. When I took off the MAF today there was an area that was worn down pretty bad. Looks like it had been rubbing against the belt for a few days. When everything is connected there is no metal exposed or anything so I'm hoping its not shot but Im not going to hold my breath. Check engine light is still on. Is there any way to tell if your MAF is actually working? If you unplug it the computer just reverts to some backup program right? Any suggestions....
04-05-2012, 04:26 PM #811 years of bangin gears
- Jan 2009
- North Jersey
If it's the tube that runs to the elbow part of the cold air intake, then, most likely it is causing a leak thus tripping the SES light. MAF code. You might be able to splice some vacuum hose onto the tube and run plastic tubing of the correct diameter into the intake elbow.
04-10-2012, 06:30 AM #9I like turtles
- Aug 2007
- Corn and Soybean fields
If cleaning the sensor is the fix it could take up to a few hours or more to clear the code without a scan tool. If you have acess to one that reads more than just codes you can pull up the data stream and see what your maf reads. If low readings are coming from the maf verify any vacuum leaks or the cold air kit is sucking in air after the maf. If no such conditions exist the maf is shot or wires were damaged. Check your a/c fuse also for the a/c code but some cars a maf code will set other codes as well
Help: 00 t/a ws6 check engine code help
By trixysrace11 in forum Firebird / WS6Replies: 5Last Post: 06-18-2012, 04:32 PM -
Check engine light
By Dave-TransAm in forum V6Replies: 5Last Post: 06-02-2012, 12:24 PM -
Check engine light
By B4C Camaro in forum Camaro / SSReplies: 1Last Post: 06-28-2009, 07:25 PM -
SLP Lid now check engine is on what's up with that
By Durango in forum Firebird / WS6Replies: 24Last Post: 04-14-2009, 05:34 PM -
Check engine trouble
By tals199 in forum Computer & TuningReplies: 9Last Post: 02-02-2008, 05:42 PM
