Thread: Check engine light
06-02-2012, 01:12 AM #1
Check engine light
I borrowed my friend's OBD2 code reader and the code that showed up is P1441. Anyone know what the code stands for? Thanks for any help. Oh and I just replaced an O2 sensor and the catalytic converter.
06-02-2012, 02:57 AM #2Your friendly policeman
- Jan 2012
- Alabama
Bright Rally Red- 2001 Chevy Camaro Z28
It's an evaporative emissions code due to a problem with your evaporative emissions system on your car. Don't have much experience with this one, but you might check your gas cap and make sure it's on good and isn't faulty, since I believe this will set the code you mentioned.
2001 Chevy Camaro Z28 A4
SLP cold air intake/lid, SLP smooth bellow, Pacesetter LT's, ORY, Magnaflow exhaust, BMR STB, adjustable Panhard rod, SFC's, LCA's, 1LE sway bars, cross-drilled rotors
06-02-2012, 03:52 AM #3Senior Member
- Nov 2006
- Indianapolis
It's a code for evap emissions flow when it's not supposed to. Your purge valve could be stuck open.
06-02-2012, 04:04 AM #4
The purge solenoid is located in your UI right next to your thermostat housing.
The bolt is a 10mm. The solenoid has a rubber o-ring on a nipple that seats down into a small bore,,
so it may take a little force to get it free of the manifold.
Make sure here's nothing jammed or any left over O-ring left in the nipple bore before replacing the purge solenoid.
06-02-2012, 06:58 AM #5
http://www.ls1.com/forums/f6/sticky-maybe-122570/ and here is the thread in the general help section. Lots of good stuff in there. Read through it all when you can. Very informative.
06-02-2012, 11:24 AM #6
Thanks for all the quick replies guys! Very much appreciated!
Check Engine light vs. Service Engine light
By bigrig73 in forum Computer & TuningReplies: 1Last Post: 04-20-2010, 06:11 AM -
Question: Check Engine Light
By 550hpbird in forum Computer & TuningReplies: 3Last Post: 02-13-2010, 04:07 PM -
Check Engine Light
By SailorZ28 in forum General HelpReplies: 15Last Post: 09-28-2007, 08:45 AM -
Service engine soon light = Check engine light?
By jinxeng in forum General HelpReplies: 5Last Post: 08-11-2006, 07:34 PM -
Check Engine Light has come on.
By Jim_s in forum Camaro / SSReplies: 6Last Post: 11-11-2005, 01:00 PM
