06-03-2012, 10:18 AM #1Member
- Feb 2006
- PA (bucks county)
maple red metalic- 2000 TRANS AM WS6
00 t/a ws6 check engine code help
p0507 anyone know what this code is?
06-03-2012, 10:31 AM #2
I believe that is Idle Air Control System RPM Higher Than Expected
06-03-2012, 10:36 AM #3Member
- Feb 2006
- PA (bucks county)
@ idle the rpm is at 8 or 900
06-06-2012, 06:40 PM #4
Check for vacuum leak. Cracked hoses, missing hoses, etc.
06-18-2012, 02:16 PM #5
06-18-2012, 03:32 PM #6
Yes, that's usually the first hose to go, just replace it with a hose of the same length and you will be fine, then see of it clears the issue.
02 Z28/LS1 NBM - TIN CAN RACING
Full bolt on, weight reduction mods, dyno tuned by FROST = 330hp/342tq New PB = 12.74 @109
check engine light code
By cant.b.caught.z28 in forum General HelpReplies: 4Last Post: 07-12-2009, 08:24 AM -
check engine light and tps code?
By gogto777 in forum Computer & TuningReplies: 2Last Post: 06-16-2009, 01:21 AM -
Help: Service Engine Soon Light.engine Code No.7missfire
By josh68 in forum General HelpReplies: 10Last Post: 07-16-2008, 08:47 AM -
Ses Light On Need Someone In Chicago Area To Help Me Check The Code
By stevegrizzle in forum General HelpReplies: 11Last Post: 11-04-2007, 09:24 AM -
Check engine light. P0430 code catalyst system efficiency bank 2. Question?
By Rob00Taws6 in forum General HelpReplies: 3Last Post: 08-19-2007, 03:12 PM
