09-26-2006, 06:51 AM #1
Ses Light On Need Someone In Chicago Area To Help Me Check The Code
Someone from around the Northern Suburbs of chicago, if you have a computer that checks ses codes please help me with this. I will buy you beer and pizza.
Thanks,
Steve
09-26-2006, 12:27 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
If you just want the code read to see what it is, places like Auto Zone will read it free.
09-26-2006, 12:46 PM #3Awaiting Activation
- Mar 2006
- LS1 land
yep, autozone will check it for you. Or if you are ever on the south side - I'm right by midway just off 1-55
09-26-2006, 02:58 PM #4
Like said above get the code read and post the code and well help ya figure it out.
09-27-2006, 09:21 AM #5
read code, 02. bank 2 sensor 1. had it reset no ses. should I follow up and replace it or wait for it go bad again?
09-27-2006, 09:40 AM #6
I would wait and see if it comes on again (could have been a fluke).
If it does come on then it appears that your passenger side front O2 is bad.
09-27-2006, 12:28 PM #7Senior Member
- Jul 2005
- Jacksonville, FL
I agree, see if it comes on again. If it does, post the actual code, might be that 02 trying to tell you someting else is wrong.
09-27-2006, 05:04 PM #8Junior Member
- Sep 2006
- Oregon
Red- 2000 Z28 Camaro Coupe
My 2000 Z28 Camaro Coupe has gone in five out of the six years to have Air Check Valves replaced, which is where it is right now. Is this a common problem with this car and can it be fixed other than every year into the dealer or repair shop?
09-27-2006, 07:50 PM #9
Don't waste your money haveing them replaced...each one is 15 bucks at autozone and it's harder to change your oil then it is to swap them out, unless they're siezed on
hno: As far as having it happen all the time, you could put dealer valves in there which might last longer.
Check your air tubes going to the exhaust manifolds also...if those are clogged with carbon it will throw the same code.
09-28-2006, 02:27 PM #10Senior Member
- Jul 2005
- Jacksonville, FL
Are they clogged with carbon every time - if so something else is going on. If you don't have emissions another option is to remove the AIR system and delete the codes.
09-28-2006, 07:10 PM #11Junior Member
- Sep 2006
- Oregon
Air Check
Thanks for all the tips. However, it is a situation where they are either rusted closed or open each time. New service guy had me call Chevrolet and they (Chev) will pay for it this time, and want to see if this fixes the problem. If not, then they will "investigate" and I am hoping they would make the car right. This remains to be seen. Something is faulty that keeps rusting these out, my thought is replace the whole exhaust system and start over but that probably won't happen.
11-04-2007, 09:24 AM #12Junior Member
- Sep 2006
- Oregon
Well, it happened again this year and now Chevrolet and the dealer will not honor the repair. They are telling me I don't drive the car long enough to get it hot enough to dry out the valves. Hmmm. I drive the car every day, eleven miles each way to work....hmmm, could there be an underlying problem here and eleven miles is not far enough or long enough to warm it up?
Chicago area autocrossing?
By MeGoFast in forum Mid-West MembersReplies: 0Last Post: 08-22-2010, 12:37 PM -
Looking for some help in the Chicago area
By bryceslu in forum General HelpReplies: 0Last Post: 07-15-2010, 10:54 AM -
check engine light code
By cant.b.caught.z28 in forum General HelpReplies: 4Last Post: 07-12-2009, 08:24 AM -
check engine light and tps code?
By gogto777 in forum Computer & TuningReplies: 2Last Post: 06-16-2009, 01:21 AM -
Check engine light. P0430 code catalyst system efficiency bank 2. Question?
By Rob00Taws6 in forum General HelpReplies: 3Last Post: 08-19-2007, 03:12 PM
