    saint cloud minnesota
    2004 GTO 6M
    power steering leak
    The video is a short clip of a power steering leak from my 99 camaro ss... do i replace the whole line or is there an o ring in the fitting? any help would be greatly appreciated
    thanks
    Yes there are O rings on both ends of the high pressure hose.
    have you checked around the reservoir? you have 2 o rings there that can fail too.
    This thread may help. It deals with the pump and reservoir but you can also do the o ring at the R&P easy.
    http://www.ls1.com/forums/f6/so-you-...g-leak-151991/
    2004 GTO 6M
    yeah i took off the lines and the o rings look like crap, i am gonna replace them in the morning and see what happens, thanks for the help!!
    Don't over torque the nut. It crushes the O ring and over time you'll be right where you are.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    ^^This.
    2004 GTO 6M
    ^^This.
    i put a new o ring on and it still leaked so i took the line off and found a tiny crack in the line so i guess i need a new line, neither the dealer or part stores can order this line, i even brought the part in when i went in...now what to do???
    gmpartsdirect.com you can order from them
    North Jersey
    2004 GTO M6
    ^^this
  1. So you got a Power Steering Leak
    By SMWS6TA in forum General Help
    Last Post: 02-10-2016, 03:33 PM
  2. Bizarre leak/ power steering
    By hix5000 in forum External Engine
    Last Post: 11-09-2008, 08:41 PM
  3. Power Steering Fluid Leak
    By matthewaqui in forum General Help
    Last Post: 09-08-2007, 10:47 PM
  4. Power steering leak...
    By theflash95 in forum General Help
    Last Post: 12-11-2006, 09:45 AM
  5. Power Steering Rack Leak
    By MLavigne Z/28 in forum General Help
    Last Post: 10-24-2006, 05:03 PM
