Thread: Power steering leak...
12-11-2006, 09:15 AM #1Junior Member
- Dec 2005
- Nowhere
Dealing with a 1998 Formula Firebird M6 here...
Okay... power steering is leaking from the hose that has a metal pipe on either end and a rubber hose in the middle. It hooks into the left side of the power steering pump (if you are looking at it from the front of the car) and then drops down and connects somewhere near the bottom of the engine bay (haven't had the chance to jack her up yet and look).
Does the rubber section of hose remove easily from the metal pipe on either end, or is it some fancy crimp job in which case I'll need to order a whole new hose? I can't quite see the connection where the metal pipe and rubber hose come together (haven't really looked hard enough yet), but I figured I'd ask and find out if I am in for a load of work, or just a simple fix.
Any input is appreciated.
Nick
12-11-2006, 09:24 AM #2
Thats an assembly, your gonna need a new hose with the metal ends crimped on.
12-11-2006, 09:36 AM #3Junior Member
- Dec 2005
- Nowhere
Any idea of where I could order this, or does anyone have a part #?
12-11-2006, 09:45 AM #4Junior Member
- Dec 2005
- Nowhere
Never mind... I looked it up on Advance Auto Part's website... Headed over there now...
So you got a Power Steering Leak
By SMWS6TA in forum General HelpReplies: 23Last Post: 02-10-2016, 03:33 PM -
Help: power steering leak
By kunkelz28 in forum General HelpReplies: 7Last Post: 03-24-2012, 01:57 PM -
Bizarre leak/ power steering
By hix5000 in forum External EngineReplies: 13Last Post: 11-09-2008, 08:41 PM -
Power Steering Fluid Leak
By matthewaqui in forum General HelpReplies: 4Last Post: 09-08-2007, 10:47 PM -
Power Steering Rack Leak
By MLavigne Z/28 in forum General HelpReplies: 1Last Post: 10-24-2006, 05:03 PM
