    Junior Member WHITE TA's Avatar
    Feb 2012
    Aloha oregon
    2001 Trans Am
    cold idle problems
    when the cars idling cold it has a slight tick and a little sqeak but once its warm it goes away what do you think the problem could be ? and theres no mods accept for exhaust
    normal issue with our LS1's.
    You'll get a ticking noise like you describe and after it warms up it should go away. However if the tick noise doesn't go away or gets louder then you need to see a mechanic.
    Feb 2012
    Aloha oregon
    2001 Trans Am
    it goes away after warm but i was wondering if its possible to get a cold idle without that tick ? would a tune up help ?
    No tune will help
    Almost all of these cars that are in regions that get regular temps below 40* will get this.
    Some ppl have experimented with using different oil weights or in places like Alaska & Canada they use engine heaters so that they can prevent their fluids form freezing.
    Member chris1974's Avatar
    Jan 2012
    Houston
    Bright Red
    1998 Firebird Formula LS1
    I'm glad you said that Scott. My LS1 does that...it's been driving me crazy since I bought it a couple weeks ago. And you're right...goes away after she's warm. I wish there was something I could do about it....but if not, that's okay too. I love her- ticking and all. lol
    Member godless-phoenix's Avatar
    culver city, Ca.
    Blackened fire chicken
    2000 Pontiac Trans Am WS6
    its funny cause i have the complete opposite...my car idles rough after its all the way warmed up. no ticking/squeaks or anything...
    clean maf, look for vacuum leaks.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Is it a belt squeal? I know certain belts cause a squeal when cold/wet.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Quote Originally Posted by WHITE TA View Post
    It sounds normal. The tick is part of living with an LS1 and the squeak is from the belts until they warm up.
  1. How To Fix Idle Problems - Idle Time
    Last Post: 04-05-2012, 07:50 PM
  2. Question: Low Idle when cold
    By jfl330 in forum Computer & Tuning
    Last Post: 04-08-2011, 04:53 AM
  3. 98 camaro cold idle problems
    By lsruthles in forum General Help
    Last Post: 12-08-2010, 07:04 PM
  4. low idle when cold
    By northslider in forum General Help
    Last Post: 01-16-2010, 09:58 PM
  5. Cold idle tick?
    By WS6ICK2K in forum General Help
    Last Post: 04-09-2008, 04:38 AM
