Results 1 to 11 of 11
    Dec 2010
    townsend, mt
    1998 Z-28 camaro
    Unhappy 98 camaro cold idle problems
    Hi everyone. I'm new to this forum and a first time owner of an ls-1. Having problems with my camaro idling at cold start-up. The only thing I have found is the tubing melted off the intake and pcv valve. I'm wondering if thats my problem and any advice would be more than welcome.
    USA
    Velocity Yellow
    2008 Corvette Z06
    Welcome to LS1.com
    Post your tech questions up the linked section, you'll get a lot more help there!
    http://www.ls1.com/forums/forumdisplay.php?f=6
    2018 Tahoe - Silver - OEM
    Dec 2010
    townsend, mt
    1998 Z-28 camaro
    K. Thanx
    A vacuum leak will generally cause a high idle issue. Other potential problems could be a dirty throttle body, a dirty or out of adjustment IAC valve on the side of the throttle body or a defective coolant temp sender. Other problems may also cause idle issues, but these are the most likely culprits. What are your symptoms?
    And... Welcome!
    USA
    Velocity Yellow
    2008 Corvette Z06
    And... Welcome!
    We just had an LS1 at the dealer with a high idle, turned out to be a leak at the intake manifold.
    Dec 2010
    townsend, mt
    1998 Z-28 camaro
    Symptoms as follows: Starts fine but idle jumps to 3000 rpm right away, then I have to feather the throttle as it drops to stall, if i catch it then it jumps back up to anywhere from 2000 to 3000 rpm and then dropps to stall again. cant apply any throttle or it will choke itself or overrev. After about five minutes of feathering the throttle it finally smooths out and runs fine till the engine gets cold again. I didnt know a faulty coolant level sensor could cause idle problems, but since you mentioned it, my coolant light comes on and goes off intermittantly since i bought the car.
    The coolant temp sensor (not level sensor) controls closed and open loop operation. If the sensor was reading high it could cause an issue upon cold start up. Does not sound like that is your problem though from what you described.
    Orlando, FL
    Mean Black
    I'll check and clean the throttle body. Check the IAC make sure is not getting stuck.
    Quote Originally Posted by lsruthles View Post
    describe this and have you fixed it? That will definitely cause a vacuum leak and could be your idle issues. If there's any air gettin into the intake via that vacuum hose that's your problem.
    the only time I've ever had an issue with a coolant temp sensor was on a buddies vette and it did exactly the opposite of this. It would start and run fine but as soon as it entered closed loop it would flood the car out.
    Zapper had a bad coolant temp sensor on his '97 and it was causing idle issues similar to what the OP described -- and it ran rich, like you just said. Had I not heard of the similar problem, it would probably be one of the last things I would ever check on an idle issue.
  1. How To Fix Idle Problems - Idle Time
    Last Post: 04-05-2012, 07:50 PM
  2. cold idle problems
    By WHITE TA in forum General Help
    Last Post: 02-18-2012, 06:57 PM
  3. Question: Low Idle when cold
    By jfl330 in forum Computer & Tuning
    Last Post: 04-08-2011, 04:53 AM
  4. low idle when cold
    By northslider in forum General Help
    Last Post: 01-16-2010, 09:58 PM
  5. Cold idle tick?
    By WS6ICK2K in forum General Help
    Last Post: 04-09-2008, 04:38 AM
