Thread: Clutch Pedal
03-28-2006, 04:25 PM #1
Clutch Pedal
I just bought a Z28 recently and I noticed sometimes the clutch pedal doesn't come back all the way after depressing it. It only happens rarely, and the clutch disengages normally, just the pedal kinda sticks. What might be causing this, and is it an easy fix?
04-05-2006, 03:38 PM #2Junior Member
- Boerne, Texas
silver- 99 trans-am
I had the same problem, you might be riding the clutch because mine only does it at the track if i am trying to feather the clutch off the line, mine stuck all the way to the floor all the way down the track and then i just pumped it a couple of times and it's fine, i don't know what causes this
04-05-2006, 03:49 PM #3
do a search on this, been discussed to naseaum on here recently
04-06-2006, 06:19 AM #4UnlimitedsGuest
Couldn't it be a throw out bearing of some sort?
04-07-2006, 08:54 AM #5<b>"iznuthn"2 a BOSS!</B>
- SF,CA
- Blog Entries
- 1
ONYX BLACK- 02 Z28
that might be part of it which is attached to ur slave cylinder. i just changed mine cuz of the same problem except my car wouldn't go into gear anymore. i suggest you look at your master to your slave connection.
Clutch Pedal Pressure and Smelly Clutch
By race5050 in forum Manual TransmissionReplies: 1Last Post: 01-06-2010, 05:37 PM -
Help: Clutch Pedal
By Ghawk996 in forum Manual TransmissionReplies: 9Last Post: 09-11-2008, 11:08 PM -
Light Clutch Pedal (New Clutch)
By Rhinohuey in forum Manual TransmissionReplies: 2Last Post: 09-22-2007, 08:51 PM -
By Rhinohuey in forum Manual TransmissionReplies: 5Last Post: 09-14-2007, 02:41 PM -
Fading Clutch Pedal with new clutch
By mrbob2 in forum Manual TransmissionReplies: 2Last Post: 08-17-2007, 05:58 PM
