    Member Edward-T's Avatar
    Jun 2011
    N.C.
    Blue
    2002-WS6
    o2 sensor, which one to buy??
    my o2 went bad on the way to work this morning, my question is do i buy one for a 2005 LQ4 (the motor in the car) or a 2002 T/A, the car itself.
    Tulsa,OK
    Quick Silver
    2002 Z06
    Strange no one else has chimed in on this one.
    If your running the factory PCM then I would guess you stick with a Delco Sensor. Some people switch to the Bosch since they have longer leads but I had trouble with them on my factory tune and went back to Delcos with O/2 Extensions.
    Really should look at what you have down there and try to match it.
    Camaro Owners Click Here
    Firebird Owners Click Here
    www.AutoTrix.net
    Jun 2011
    N.C.
    Blue
    2002-WS6
    i will take one out and match it up, the 6.0 was already in there when i bought it, but i remember the owner telling me it was the factory LS1 pcm, with a tune and i have had a retune done on it as well, he also said i could take the 02's out and clean them with rubbing alcohol, any truth to that?
    Tulsa,OK
    Quick Silver
    2002 Z06
    Never have heard of doing that. I doubt the alcohol would realy clean up the carbon that much. It depends on how valuable $100 is to you Personally I'd throw on a brand new one and call it a day but if your time is no big deal the worst you can do is commit to buying a new one LOL
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Factory PCM, factory-spec sensors. At least, that's how I would do things.
    Jun 2011
    N.C.
    Blue
    2002-WS6
    cool, thanks guys!
  1. Help: 02 sensor bank 1 sensor 1-Is this drivers side or Passenger
    By cballweg in forum General Help
    Last Post: 01-15-2012, 11:44 AM
  2. Question: Reading trans temp stock sensor vs aftermarket sensor in pan
    By senicalj4579 in forum Computer & Tuning
    Last Post: 03-29-2011, 08:41 AM
  3. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 09:28 AM
