01-15-2012, 10:07 AM #1Junior Member
- Aug 2011
- St.Marys
Red- 1999 Ram Air Trans Am
02 sensor bank 1 sensor 1-Is this drivers side or Passenger
I have a check engine light code P0135 on my 1999 LS1 Trans Am that I looked up and it says 02 sensor bank 1 sensor 1 and Im wondering if this is drivers or passenger side and is this the one closest to the motor and where is this located.Any help would be much appreciated.Thanks for your help.
1999 Ram Air Trans Am-6 speed-Whisper lid,BG Ram Air,MS-4 cam,Thyphoon 85mm intake and throttle body,LT headers,Borla catback,#36 injectors,high volumn fuel pump,4:11 gears,sub frame connectors
01-15-2012, 10:17 AM #2
You are correct. Bank 1 is the driver's side and sensor 1 is the O2 sensor upstream of the catalytic converter.
01-15-2012, 10:19 AM #3Junior Member
- May 2009
- Santa Maria, California
Black- 1998 Pontiac Formula LS6
I think it's the upstream driver's side sensor. They're fairly simple to remove. You can always swap the upstream with the downstream sensor to isolate the problem. All four sensors are swap-able. In the books the sensors have been superseded by the same part no.
01-15-2012, 10:28 AM #4Junior Member
- Aug 2011
- St.Marys
Thanks for your help.I have long tube headrers so I believe Ill have to get it from under the car since they are at the back of the headers
01-15-2012, 10:44 AM #5
You can access from underneath. I believe the wrench size is 7/8"
Help: Drivers side is way lower than passenger side......
By 98TransAmWs-6 in forum Suspension and HandlingReplies: 23Last Post: 10-10-2012, 10:21 AM -
Bank 1 and 2 sensor 1 no activity
By Tx98Formula in forum General HelpReplies: 34Last Post: 03-07-2010, 05:13 PM -
Bank 1 O2 Sensor
By robert 98 in forum General HelpReplies: 5Last Post: 09-23-2009, 02:10 PM -
Help, Fuel Trim on passenger side Bank
By Brutis in forum Computer & TuningReplies: 2Last Post: 07-20-2009, 10:32 AM -
bank 1 bank 2 sensor locations?
By Hector in forum General HelpReplies: 6Last Post: 03-13-2007, 05:23 PM
