Thread: A/C Grinding metal noise
07-21-2011, 05:37 PM #1
When I start my car there is a grinding metal sound coming from the compressor I believe (the belt is spinning but not the middle part). When I fill it with freon it will start to spin and the sound stops but then it blows the fuse. What could be wrong? Also it doesnt Leak at all, it holds the same pressure when I checked it a few weeks ago until now. We did replace the engine, so maybe I need to vaccum it? IM really not sure what to do. I would be greatful for any help. Thanks
probly shoulda posted in general section. EWpsLast edited by Justin23454; 07-21-2011 at 05:43 PM.
07-21-2011, 07:47 PM #2
It sounds like it could be a bad Compressor clutch. If the fuse blows when the Clutch is engaged its probably drawing too may amps.
07-22-2011, 06:41 AM #3
ok thanks, do you know about how much that might be to fix? to hot here now! Gonna be 100+ sigh
SLP lid, SLP CAI, K&N air filter, Ac Delco Iridium plugs, Gutted Cats, QTP 3'', TB Bypass, LT headers w/ORY,
07-22-2011, 05:21 PM #4
Not sure about the cost. You would most likely replace the compressor it self. If its just the clutch you may be able to have someone rebuild it.
07-28-2011, 08:05 PM #5
I Just ended up vacuuming it for 50 mins, and replacing all fluids, and now its working! SO glad I didnt have to get a new compressor or anything. Thanks for the help.
Grinding noise???
By 1986camarojoe in forum Suspension and HandlingReplies: 3Last Post: 09-30-2008, 10:54 PM -
A low grinding noise.
By GTO Joe in forum GTOReplies: 8Last Post: 03-06-2007, 08:54 AM -
Istalled new pushrods, now new metal on metal noise
By brokenls1 in forum Internal EngineReplies: 0Last Post: 02-02-2006, 03:29 PM -
Grinding noise
By transam_9706 in forum Manual TransmissionReplies: 0Last Post: 01-13-2006, 02:43 PM -
Grinding Noise?
By Fast95Bird in forum General HelpReplies: 1Last Post: 11-08-2005, 11:55 AM
