Results 1 to 1 of 1
02-02-2006, 03:29 PM #1Junior Member
- So Cal
Artic White- 99 SS
Istalled new pushrods, now new metal on metal noise
So my car was sounding like I had a bent push rod or two, actually it sounded like I bent them all, was pretty bad. So I ordered a set of Comp Cam 7955-16 pushrods. Couldn't tell which side the noise was coming from so I start with the passenger side because it looked easier. Find one that is so bent that it looks comical and the hole in the head it goes through is elongated. This same pushrod has been replaced by the dealer twice under warranty. And I also found two that were slightly bent when rolled across a piece of glass. So all 8 on the pass. side were replaced and I thought the one was the problem. Start the car up and after a couple of seconds a slight ticking starts. Then a metal on metal sound, intermittent though, a couple seconds long every five or six seconds. No SES light, but the engine is running a bit rough. It has been sitting for almost a month now if that makes a diff. So has anybody had the same thing happen, or any advice for me?
Thanks
A/C Grinding metal noise
By Justin23454 in forum External EngineReplies: 4Last Post: 07-28-2011, 08:05 PM -
Ron Fournier: Metal Fabricator - Metal Man
By Ed Blown Vert in forum Almost Anything GoesReplies: 1Last Post: 03-03-2011, 12:47 PM -
Rear Metal Clanking Noise
By Rikki_SeVeN in forum Suspension and HandlingReplies: 4Last Post: 10-28-2008, 02:47 AM -
help--Metal in Metal chatter- need homemade gasket
By jrc1122 in forum Manual TransmissionReplies: 2Last Post: 06-03-2008, 03:30 AM -
Metal in oil HELP
By 99PTA in forum General HelpReplies: 3Last Post: 09-13-2006, 06:03 PM
