    Virginia
    Pulse Red
    2004 GTO
    A low grinding noise.
    Ok, i'm a little confused. No matter what the temperature is, hot or cold, when i start my car and put it into reverse or 1st and begin to accelerate a low grunt/grinding noise can be heard for a split second. I took it to the dealership i bought it from and they told me that it needed new exhaust mounts. Once they changed them the noise persisted and now they tell me its a relay in my car. I took it to another dealer to get their opinion and they are telling me it is an abs sensor. Would a sensor or relay really make a distinguishable grinding noise from inside and outside of the car? And on another note, this has just started happening when i am in first gear and doing a u turn or while im steadily turning left. Any suggestions? 04 gto w/ only 9k miles on it...
    Member Tide's Avatar
    Southeast
    Nothing special
    Nothing special
    What RPM's are you at?
    Virginia
    Pulse Red
    2004 GTO
    Quote Originally Posted by Wade M View Post
    like 1-1.2k rpms ... Like backing up out of a parking lot/driveway slowly or first when you just release the clutch and start going.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    hmmmm.... does it ever happen BEFORE you move? or just when you start moving? You say it makes a grinding noise when you turn? Is it a metal on metal noise? If so, i dont know how the dealership said a relay. How many miles on tha car? I dont understand why these dealerships keep saying sensors and relays. How can a noise go from exhaust mount to relays? The car seems too new for a wheel bearing to start going, but its possible. Mine started out just making a metal on metal noise every once in a while. Then finally spit the bearing's out. Get back to us on this.
    Southeast
    Nothing special
    Nothing special
    If it was a bearing, you'd think it would be more pronounced at speed.
    Any unusual vibrations at highway speeds?
    Junior Member ls1hoon's Avatar
    melbourne, australia
    2002 Holden Commodore SS
    weird
    here
    2001
    mine does the same.......i've been thinking its the breaks.....after i get my new set up on i'll repost to say if it helped
    Retired Outlaw Sum Bitch
    Lots of these. Pontiac has warrantied many of them.
    Virginia
    Pulse Red
    2004 GTO
    I called General Motors and they contacted the dealership i had it taken too. The dealer tells them one thing, and once i take it in they just say it's a relay. The sound is similar to a tire rubbing a fender. It happens just as i start moving.
  1. Grinding noise???
    By 1986camarojoe in forum Suspension and Handling
    Last Post: 09-30-2008, 10:54 PM
  2. grinding noise...maybe?
    By oreowizard in forum General Help
    Last Post: 01-06-2008, 04:42 AM
  3. grinding noise...
    By tigersport14 in forum Automatic Transmission
    Last Post: 10-13-2007, 08:48 AM
  4. Grinding noise
    By transam_9706 in forum Manual Transmission
    Last Post: 01-13-2006, 02:43 PM
  5. Grinding Noise?
    By Fast95Bird in forum General Help
    Last Post: 11-08-2005, 11:55 AM
