Results 1 to 13 of 13
Thread: grinding noise...
10-10-2007, 08:50 AM #1
grinding noise...
ok so the other day i was drivin, and my friend was next to me in his camaro. he noticed that when i dropped it in 2nd (we were going about 45) it made a grinding noise. its an a4 ... anyone know what it could be?
10-10-2007, 10:19 AM #2
I'm moving this to the tranny forum where you'll get more/better responses.
10-10-2007, 06:55 PM #3
ok thx. sorry about posting it in the wrong section. anyone know what the problem is?
10-10-2007, 09:38 PM #4
got headers?!?!might be rubbing against the frame...
only way of fixing that noise is by putting polyurethane bushings..or tranny mounts ..but never heard of that ..hhmm
10-11-2007, 08:22 AM #5
its a stock 04 ls1 with 5k miles
10-11-2007, 05:22 PM #6
when it shifted during wot...did it grind? if so..the rear end might need a gm additive
10-12-2007, 07:39 AM #7
ill have to check that out. thx for the help!
10-12-2007, 09:56 AM #8
i remember mine also did that when it was stock....just added the gm additive...probably a good 3-5 thousand miles laters....stopped hearing the grind noise when shift changes occured during wot
10-12-2007, 09:59 AM #9King 0f n00bz
- Jan 2006
- Shepherd, Michigan
dont shift it into 2nd when driving...its a pain on the whole tranny ect. just keep it in 3rd when you want to race...when in third and you shift you have use of 3 clutch packs i believe compared to 1-2(dont quote me on the numbers) 1 & 2 are for towing and not recomended for constant driving unless you get your self a shift kit/built tranny
10-12-2007, 10:00 AM #10King 0f n00bz
- Jan 2006
try the additive, if not i would think your gear might be screwed.
10-13-2007, 08:39 AM #11
hey shady i got a couple of questions....i changed the gear fluid while i was swapping bearings....i put lucas 60/90... whats the recommended weight i shouldve put...i noticed the stupid hum when accelerating...
10-13-2007, 08:40 AM #12
oh yeah..and would you know anywhere i could buy axles???
10-13-2007, 08:48 AM #13King 0f n00bz
- Jan 2006
look in the manual under the recommended fluids
Grinding noise???
By 1986camarojoe in forum Suspension and HandlingReplies: 3Last Post: 09-30-2008, 10:54 PM -
grinding noise...maybe?
By oreowizard in forum General HelpReplies: 5Last Post: 01-06-2008, 04:42 AM -
A low grinding noise.
By GTO Joe in forum GTOReplies: 8Last Post: 03-06-2007, 08:54 AM -
Grinding noise
By transam_9706 in forum Manual TransmissionReplies: 0Last Post: 01-13-2006, 02:43 PM -
Grinding Noise?
By Fast95Bird in forum General HelpReplies: 1Last Post: 11-08-2005, 11:55 AM
