Thread: A/C blows hot
07-01-2011, 03:14 PM #1Junior Member
- Apr 2009
- Sanford, NC
Red- 2000 Pontiac Firehawk
A/C blows hot
For the past few months my A/C has blown hot and I just decided to take a look at it. I started by re-charging it. That didn't work. The clutch is engaging the compressor. The fuses/relays look fine. I don't see any leaks. When I turn the A/C on I do now notice that the compressor is making a somewhat loud almost grinding/clicking noise. Just noticed this noise since I recharged it (might just be coincidence). Any ideas where to go from here? I don't want to replace compressor if I don't need to.
07-01-2011, 04:58 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
My 98 had some leaks that I discovered last year when it started blowing warmish. Recharged it and it only lasted a few days. Car has 183,xxx on it so I ended up replacing almost everything as you can't go without AC here in the PHX.
Well you could but I won't...67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
07-02-2011, 02:08 AM #3
The only way you can lose refrigerant is through a leak.. Whether it's a fitting, bad compressor, line, etc. If the compressor is bad, it may not be pumping properly. You can take it to a reputable shop so they can add dye to the system and locate any leaks. And/or, determine whether the pump is bad or not.
Generally speaking, if the pump is making noises that it never made before it could be the pump is shot or dieing..
When refrigerant levels fall to a sertain point the clutch will stop working and the pump won't run..
Seperately,, Not only can it be dangerous to over fill the system, it can have damaging effects on the pump..
Since most R134a contains pump lube, Ima have to say the pump is prolly gone..Last edited by Smittro; 07-02-2011 at 02:10 AM.
07-02-2011, 09:06 AM #4Junior Member
- Apr 2009
- Sanford, NC
Where is the pump located? Is it part of the compressor?
07-02-2011, 12:57 PM #5
07-02-2011, 05:03 PM #6Junior Member
- Apr 2009
- Sanford, NC
ok cool thanks for the info!
07-03-2011, 12:45 PM #7
07-04-2011, 03:36 AM #8
You need to put a set of pressure gauges on the lines and read the pressures. As I understand from the first post,refridgerant was added but didn't fix the problem.
A clogged orifice tube,inop cooling fans or a bad compressor can all cause poor a/c performance
07-06-2011, 11:07 AM #9
also could be over charged.. it then will also act like its low on freon... really need to check the pressure with a good set of gauges...
AC blows not so conditioned air.
By Kramsdell in forum General HelpReplies: 11Last Post: 08-15-2011, 03:33 PM -
Question: AC only blows out into floor
By Speedy_Gonzales in forum External EngineReplies: 16Last Post: 06-03-2009, 01:16 AM -
when it blows, what breaks?
By LT1 > LS1 in forum DrivetrainReplies: 12Last Post: 09-14-2008, 12:02 PM -
AC blows warm air
By apache in forum General HelpReplies: 25Last Post: 07-03-2008, 06:46 PM -
A/C blows cold only sometimes now...
By AKIRA in forum General HelpReplies: 1Last Post: 03-27-2008, 04:54 PM
