View Poll Results: Best value heads for LS1?
Voters
142. You may not vote on this poll
  • Edelbrock
    3 2.11%
  • Trick Flow
    11 7.75%
  • DART
    17 11.97%
  • AFR 205cc
    70 49.30%
  • LS6 P&P
    40 28.17%
  • LS1 P&P
    3 2.11%
Multiple Choice Poll.
Page 1 of 5 12345 LastLast
Results 1 to 20 of 95
    Evr sena bdgr killa snak? Roastem's Avatar
    Research Triangle Park, NC
    '99 Z28 M6
    Need heads! Which set makes the most power?
    OK fellas, I have decided I will not be waiting till next year for the heads, I want it NOW! Problem is, there are many choices.
    AFR 205cc
    Edelbrock
    Trick Flow
    DART
    LS1 ported & polished
    LS6 ported & polished
    Which one of these heads would be best for my combo? (see sig) Oh yeah, and money is an object. (when is it not)
    Heads 'n Cammed, Moser 12, 3.73's, Weight Reduction, 13" Brembo Kit
    BMR track suspension, full exhaust, the works...
    412whp/394wtq 1/4 mile slip coming soon!
    Gone: '01 Laser Red Cobra 3.73's/Full Bolt-ons
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    AFR are the best but being that money is an object I would go with Patriot.
    central wisconsin
    what cam do you have? I am assuming you have a stock block?
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    Another vote for Patriot - I'd run LS6 style heads with stock size combustion chambers with your cam.
    Will AFR's make more power? Yes.
    Will they make twice as much power, given they cost twice as much? Probably not.
    Hammer - hammertime.us
    2001 Light Pewter Metallic Camaro SS, 6 speed
    K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
    '99 Z28 M6
    Quote Originally Posted by hammertime
    I was leaning towards the P&P LS6 heads, too.
    West Texas
    Rivera Blue
    2002 Chevrolet Camaro Z28
    I have a set of brand new 5.3L GM castings with CNC Incorporated's port job ran through them if your interested?
    Never used.
    '99 Z28 M6
    Quote Originally Posted by onelife
    Never used.
    How are those different from LS6 heads? I am interested, depending on your price.
    West Texas
    Rivera Blue
    These heads are ported by CNC Inc., they will outflow any stock non-ported LS6 heads which also run around $1,200 new from any GMPerformance parts dealer.
    Plus the combustion chambers are smaller (all 5.3 heads have them) so they will raise your compression without the hassle of milling your heads or shortening your deck height (which will cause problems).
    CNC Inc used to charge $2,200 just for the CNC port job plus you supply your own heads to them, these castings are absolutely new, never been used.
    I was going to installed them this June but my stock pressure plate and clutch gave up the ghost.I was saving up for ARP Head Studs, Cometic Head Gaskets, Comp Valve train, and Manley Valves. I already have a good cam in my stock block so I was just going to slap the heads on but now I have to buy a Spec Clutch and Flywheel. They aren't the cheapest heads but they are one of the best. Let me know if your still interested.
    Crystal Lake IL
    2001 Camaro Z28 M6
    just because a specific heads might flow the best CFM doesnt mean it makes the most hp. Heads are just a cog in the complete machine.
    Before spending cash on heads, decide what you performance goals and driving styles are.
    If you only plan on doing heads and headers then yeah by the highest flowing heads, but if you plan on doing cam, turbo, nitrous etc, match the heads to the application for the most performance gain.
    For ex: ET makes two great heads 215 and 225. 225 flow more, but you will get better gains with 215 for a nitrous build then you will with the 225.
    buying huge claimed hp parts and sticking them all together doesnt make a fast car. buying parts that compliment eachother do! (for example, matching intake and exhaust cfm on both the cam and the heads)
    also the brands you have listed are popular brands but there are many other great heads out there.
    hence ET, RGR, etc....
    West Texas
    Rivera Blue
    These heads are proven street performers, the recommended cam for these heads on a stock bottom end is 224/228 duration with a .571"/.571" lift.
    With all the necessary bolt ons, on an F-Body it will generate around 425HP and on a Y-Body it will around generate 450HP; respectively.
    ibanez7, calm down, why are you so wound up? Aren't the ET and RGR expensive heads? I'm not saying cut corners but some people cannot afford an $8,000 setup when they would be satisfied with a $2,500 setup.
    Yes, CFM head flows aren't the precise measurement in choosing a street head but what other numbers are you going to by besides port cc's in choosing a new design? There is a name for applying non-stock,modified, and unfamilar parts to your sports car; its called racing.
    '99 Z28 M6
    2200 for a port job! GOTDAMN! I said..I said..GOTDAMN!!!!
    Your price might be out of my spending range, but tell me anyway how much you want for those heads.
    Crystal Lake IL
    2001 Camaro Z28 M6
    dude, i'm cool. I just dont believe in buying off the shelfs cams. You should always get a custom grind that compliments everything from the heads, driving style, to the rearend gearing.
    too many people, buy parts based off of hp claims not realizing you should always buy parts that compliment. Also you should always build from the ground up.
    your right a $2500 set up like speed inc, patriot head and custom grind cam package for $2200 is a great set up, and you can turn in some impressive numbers with reliability too!
    Moo cow f**k milk Demon_Speeding's Avatar
    New Mexico...from Kansas City
    2001 Camaro Z28
    Check out the Texas Speed PRC 243 heads.
    TSP/PRC LS6 heads
    Compare their flow numbers to the AFRs. I'm getting mine ordered pretty damn quick. I'm going to run those heads with an MS3 camshaft.
    '99 Z28 M6
    Quote Originally Posted by Demon_Speeding
    TSP/PRC LS6 heads
    Wonder what the price is with bare castings?
    West Texas
    Rivera Blue
    I need to sell my heads for $1,000, Roastem.
    Senior Member Corona-Extra's Avatar
    Houston Texas
    Black SVT & Silver WS6
    2003 SVT Cobra & 2002 WS6
    No replacement for displacement.
    Member TwistedSS's Avatar
    Irmo, SC
    Quote Originally Posted by Liquifire
    +1
    ET Performance Heads (carried at ls1speed.com or from SDPC2000.com)
    They are a 11 degree heads with taller walls (so you don't need a valve cover spacer) and a thicker deck. You will need a longer push rod (like around 8in or more) due to the taller deck and change in valve angle.
    But if money is no OBJECT then the ETP's are the way to go.
    They also have a Baby LS7 head but you will need a bore of 4.00 or better (valve's will hit the walls on a 3.90 bore)....
    If you want inexpensive (best bang for the buck) then it's going to be Patriot's LS6 Stage 2 or Stage 3 heads.
    Junior Member Louie's Avatar
    Ohio
    2000 WS6
    Quote Originally Posted by ibanez7
    All of the best numbers I've seen come from proven cams - MS3, T-Rex, F13, Torquer 2, etc. I have yet to see any stellar performing custom ground cams in 346.
    I wouldn't take a gamble on getting a custom ground cam when you know for a fact that these proven cams perform time and time again.
    Ohio
    2000 WS6
    Oh, and as for heads, if money is not an object than AFR's.
    Otherwise, I've seen some awesome numbers from the very well priced TSP's PRC LS6 heads.
  1. Question: cams, heads want power!!!
    By rooster in forum Internal Engine
    Last Post: 06-20-2010, 07:12 AM
  2. Question: what cam and heads should i get for most power
    By aleonard in forum Internal Engine
    Last Post: 06-07-2010, 08:06 AM
  3. Which header makes more power
    By MiguelLS1 in forum External Engine
    Last Post: 09-25-2007, 03:03 AM
  4. how to get more power from stock heads
    By Semperfiws6 in forum Internal Engine
    Last Post: 08-01-2007, 09:12 PM
  5. exhaust.... what makes more power?
    By EVL LS1 in forum General Help
    Last Post: 11-21-2005, 07:40 PM
