    Junior Member rooster's Avatar
    Norfolk
    2000 Trans-Am
    cams, heads want power!!!
    I have a 2000 ta i just went to a place called EFI Alchemy for estements on my car i plan on putting about 10 into the car. They told for start the best thing to do was to start out with a cam, heads, changing the stock 27 pound injectors to 42 pound injectors, tune and so suspention mods. I am stock under the hood I have a spec stage 3+, 9 inch rear end with 4:10, detroit lockers. Any suggestions?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I would build your drive train and suspension first. You have a great start with your clutch and rear. Do you have SFCs, LCAs, LCA relocation brackets, or a TA?
    Are you a M6 or A4? Is this a DD? Guessing no if you have a locker. Maybe not.
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    Did you go top the EFI Alchemy down here in the Jacksonville area in Green Cove Springs? Its the only one I knew of but maybe theres more. Anyway Doc at the one down here really knows his stuff and doesnt rip people off either, I would trust what he says.
    Norfolk
    2000 Trans-Am
    i planned on doing shocks and a new torgue arm as well as a new sway bar.
    Norfolk
    2000 Trans-Am
    yes the one in Green Cove i was told they were a great place to go i just wanted to check to see what other people had to say.
    Jun 2009
    coon rapids, MN
    2000TA
    are you doing the work your self?
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    Yeah they are great guys over there. Anything I cannot do myself gets done there. They have a great rep for a reason. Doc really knows his shit too. I will be in there with in the next few weeks for a dual nitrous/na tune and a few other things.
    Member BlackSS1's Avatar
    Lexington, NC
    2001 Camaro SS Vert
    Quote Originally Posted by rooster View Post
    If you do the heads/cam, plan on an upgraded intake manifold if you do not already have one. LS6 or a FAST will help you get the most power out of your motor. Your stock ls1 manifold will starve a modified motor.
    Wish I had 10 to put into my car!
    Jun 2009
    coon rapids, MN
    2000TA
    vengeance racing head/cam kit,or TSP head/cam kit.
  1. HELP on Cams and Heads!
    By fatslayer in forum Internal Engine
    Last Post: 08-26-2010, 08:16 AM
  2. Cams and Heads HELP
    By fatslayer in forum GM Trucks
    Last Post: 08-17-2010, 05:43 AM
  3. smog; heads and cams
    By 346DubS6 in forum Internal Engine
    Last Post: 11-05-2007, 07:45 PM
  4. What cam to get maybe cams and heads help!
    By bgable in forum Internal Engine
    Last Post: 09-13-2007, 03:55 PM
  5. Help A Newb! Cams/Heads
    By Tonik in forum Internal Engine
    Last Post: 03-27-2006, 08:20 PM
