Thread: P0101 & p0155?
05-23-2011, 10:43 AM #1Junior Member
- May 2011
- TEXAS
- 2001 Silverado
P0101 & p0155?
truck is throwin these 2 codes and running like crap. a/f is all over the place. i know the first has to do with the maf and the second is o2. i just replaced the maf and that didn't seem to help any. where should i go from here? thanks
05-23-2011, 11:05 AM #2O U 8 1 2
- Nov 1999
- over here...
check your cats to make sure they aren't clogged...
05-23-2011, 12:12 PM #3Junior Member
- May 2011
- TEXAS
- 2001 Silverado
no cats, just shells
05-23-2011, 12:32 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
Might not be the answer...but on the F-body the MAF and 02's (couple more things for M6) are on the same ENG SEN fuse circuit. If yours is the same something easy to check first.
05-23-2011, 02:03 PM #5Junior Member
- May 2011
- TEXAS
- 2001 Silverado
which fuse is this? i didn't see an eng ses fuse in the fuse box.
05-23-2011, 02:37 PM #6Senior Member
- Jul 2005
- Jacksonville, FL
On F-bodies ENG SEN = Engine Sensor. Look at the fuse into in your owners manual, should list everything on the circuit if it's there. Ours is under the hood.
05-24-2011, 09:54 AM #7Junior Member
- May 2011
- TEXAS
- 2001 Silverado
all the engine managment fuses are good. i'll check again for any vacuum leaks again this afternoon but after that, i'm stumped..
05-27-2011, 05:08 AM #8
air filter
Make sure your air filter is clean. I have Volant intake with K&N's and had the same codes popping. My car however was not running too bad. I cleaned the filters and the code disappeared (for now). Just a suggestion
Help: P0155 & P0135 codes
By fna7302 in forum Computer & TuningReplies: 3Last Post: 04-09-2015, 08:07 PM -
p0101?
By CHEVY211 in forum General HelpReplies: 6Last Post: 06-14-2011, 04:35 PM -
low idle and p0155 code
By slpdablueZ28 in forum General HelpReplies: 4Last Post: 04-06-2010, 03:01 PM -
P0101 - maf?
By turbojimmy in forum General HelpReplies: 6Last Post: 03-27-2010, 08:47 AM -
Question: code P0101
By pmolina0436 in forum GTOReplies: 3Last Post: 04-24-2009, 08:30 PM
