Thread: P0101 - maf?
    Member turbojimmy's Avatar
    Feb 2007
    NJ
    2002 Trans Am Convertible
    P0101 - maf?
    Hi all,
    My car has been acting weird the past few weeks, bucking and hesitating. Yesterday the SES light finally came on with a P0101 code.
    I recently installed a Firehawk hood on the car, introducing the 'ram air' effect to what was a bone stock, base TA. Could this have anything to do with it? Does the PCM need reset? I can't imagine that the ram air effect is substantial enough to affect what the MAF sees, but I guess you never know.
    Or, should I just replace the MAF?
    TIA
    East of Cleveland, Ohio
    99 WS.6 - Modified
    Try some maf cleaner. Pick it up at your local parts store. Might just be dirty.
    Feb 2007
    NJ
    Thanks - I'll try that first.
    Feb 2007
    NJ
    I picked up some of that CRC stuff and cleaned it. It didn't look dirty, and the air cleaner looked decent, but I went through the exercise anyway. Took the car out briefly and it *seems* ok now. It did it mostly under a heavy load, like when I'm too lazy to drop a gear and accelerate.
    Time will tell, I guess.
    If I do replace the MAF eventually, is there any benefit to an SLP MAF, or any other bigger MAF?
    Jim
    As the saying goes on here -- Leave the MAF alone!
    The aftermarket MAFs skew the air/fuel on our cars and this can only be corrected with tuning. The stock MAF is actually good to up around 500 h.p. Also, you should not de-blade or de-screen your MAF as that also alters the airflow and throws off your air/fuel. Greg Banish, a recognized GM tuner and author has addressed this in both of his EFI/Tuning books. You will see mucho debate about this on here, but the facts are the facts.
    Feb 2007
    NJ
    Thanks. Hopefully I won't need to replace it, but that's good info.
    Senior Member
    texas
    2000 formula
    get a SD tune
  1. Car is throwing P0101 code
    By randepandy in forum Computer & Tuning
    Last Post: 06-18-2012, 06:36 AM
  2. p0101?
    By CHEVY211 in forum General Help
    Last Post: 06-14-2011, 04:35 PM
  3. P0101 & p0155?
    By srv8800 in forum General Help
    Last Post: 05-27-2011, 05:08 AM
  4. Question: code P0101
    By pmolina0436 in forum GTO
    Last Post: 04-24-2009, 08:30 PM
  5. P0101 Code Help
    By axxdet in forum General Help
    Last Post: 03-10-2009, 08:02 AM
