Thread: P0155 & P0135 codes
04-09-2015, 07:20 PM #1Junior Member
- Mar 2013
- rhode island
silver- 2002 T/A
P0155 & P0135 codes
I have a 2002 T/A with an LS6 engine and keep getting P0135 & P0155 codes...car is running in closed loop most of the time. Wiring has been tested and is OK. Coolant system is working normally. All sensor have been replaced and are new. Car has ARH long tube headers. Freeze frame data shows normal fuel trims and normal o2 sensor operation. The exhaust has multiple pin hole leaks downstream starting about 2' after the bank 2 sensors. The leaks are from band clamp style clamps.
Does anyone have any advice/insight on what may be causing this and how I can fix it? Thanks in advance for any information you can lend.
04-09-2015, 07:53 PM #2
what sensors are you running? Those are heater codes and are pretty common with longtubes. Not everyone gets them but quite a few do. I switched to bosch 13111 sensor some years ago and haven't had a heater code since. I believe firebirdjones also had the same luck when switching to 13111 sensors. That's actually the part number for rear sensors on the vettes. They have a longer harness and *supposedly* have a better heater in them. Not sure how much I believe the heater stuff but I will say I haven't had a heater code since switching and that's been at least 5 years ago....probably more.
04-09-2015, 07:55 PM #3Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
2000 Black TA M6 - LT's, ORY, UMI Short Stick, TT2's, Drilled/Slotted Rotors, Braided Lines, and Tuned by Vengeance
SCCA and Car Show Approved
06 Quad Cab HHHHemi - Sold
97 Camaro - Sold
04-09-2015, 08:07 PM #4Junior Member
- Mar 2013
- rhode island
silver- 2002 T/A
Great question and not sure as they were just changed recently...I'll check with my friend who is trying to diagnose this problem and will get back to you via this thread-thanks so much for the prompt response
P0135 Help ASAP
By WS6ICK2K in forum Computer & TuningReplies: 23Last Post: 01-15-2012, 12:20 PM -
P0101 & p0155?
By srv8800 in forum General HelpReplies: 7Last Post: 05-27-2011, 05:08 AM -
low idle and p0155 code
By slpdablueZ28 in forum General HelpReplies: 4Last Post: 04-06-2010, 03:01 PM -
Question: Codes p0135 p0155 and p1258
By buswwa in forum Computer & TuningReplies: 4Last Post: 12-04-2008, 09:51 AM -
SES light with 2 codes....P0155 & P0174???
By danman in forum General HelpReplies: 3Last Post: 05-31-2006, 10:34 AM
