Results 1 to 10 of 10
Thread: Fuel Injectors
05-20-2011, 08:12 AM #1Spaz is My Mentor
Fuel Injectors
I've been trying to find what I believe is a vacuum leak and I think I may have found it. I think my injectors are not completely sealing and are letting in some air.
Is there a size difference between the 98' 28lb injectors and the 02' 28 lb injectors?
98's have the LS1 intake while the 02's have the LS6 intake. I ask because my fuel injectors have a bitch of a time sliding into the LS6 intake and have no issues with the LS1.
I've seen no fuel leaks or have had no miss fire issues or any lean codes pop up yet.
05-20-2011, 08:30 AM #2ls1 powered seabee
- Mar 2007
- oxnard, ca.
red and black- 1999 Formula/WS6
fittment should be the same if i remember....try replacing the o-rings on the injectors, should help them get seated better.
05-20-2011, 08:41 AM #3Spaz is My Mentor
I get 2 different part numbers.
98' Part # 12533952
02" Part # 12482704
05-20-2011, 08:42 AM #4ls1 powered seabee
- Mar 2007
- oxnard, ca.
thats probably just because there differnt injectors, however, size should be the same for seating purposes.
05-20-2011, 08:57 AM #5
Have you tried the spray test to see if the idle picks up or surges?
Carb cleaner or brake cleaner work good.
05-20-2011, 09:00 AM #6
05-20-2011, 09:08 AM #7Slow'er'Ass
- Thornton, CO
O-rings may vary from 98 to 02. Both should work though. Use the newer part number (as with anything that is the same) from GM.
I use a VERY small amount of vaseline on the o-rings prior to seating them. The ones I have on the T/A were very tight going into the LS1Speed rails and the FAST90.
I don't see an o-ring being the problem here though. Do the carb cleaner test though just to be sure.
05-20-2011, 09:10 AM #8
05-20-2011, 11:43 AM #9
05-20-2011, 01:05 PM #10
Question: Fuel injectors
By kingls1 in forum General HelpReplies: 46Last Post: 01-30-2014, 10:34 AM -
Question: 95 LT1 fuel injectors
By 02 Camaro SS SLP in forum Camaro / SSReplies: 1Last Post: 07-28-2010, 05:34 PM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 02:26 PM -
fuel injectors
By Brad5150 in forum External EngineReplies: 10Last Post: 05-30-2007, 01:26 PM -
smaller fuel injectors means more fuel?
By Ger-Fire in forum LT1Replies: 5Last Post: 10-12-2006, 03:06 PM
