Results 1 to 11 of 11
Thread: fuel injectors
03-05-2007, 01:54 PM #1Junior Member
- Oct 2006
- US
fuel injectors
so fuel injectors should be replaced every 80-100k miles right? i ahve 104k on mine so i guess its time. what should i get, how many LBS and how much doesit cost?
03-05-2007, 03:52 PM #2Senior Member
- Nov 2006
- Indianapolis
No, no need to replace them unless shorted/clogged/open circuit. Especially if you have been running premium from a major gas company, they will stay clean. Any other opinions?
03-06-2007, 06:00 AM #3
If you are going to replace them, just get some that are the same flow rate, or else you will need a new tune. Factory injectors should be fine, but you could go aftermarket, might be cheaper. Only get a higher flow rate if you have a setup that demands more fuel, like a power adder.
03-06-2007, 07:26 AM #4
No
I wouldn't change them unless they are causing you a problem. You can pass a can/bottle of fuel injector cleaner from time to time if you like. I wouldn't worry with it.
2000 Z28 M6, SLP Lid, SLP Bellows, SLP UD,
P&P Maf, TB By-Pass, PS Shorties, LS6 Intake, FAST 78mm TB, Hooker CB, Hurst Billet, Front Tower Brace, small 218/218....527/527....114 cam.
337rwhp/348rwtq
03-08-2007, 07:22 PM #5Member
- RIGHT BESIDE THE LEMON TREE IN HELL!!!
LIGHT PEWTER METALIC- 1999 SS CAMARO
what is the stock lbs per hour?
03-08-2007, 07:25 PM #6
On the 94 and up LT1's, it was 24. But for the LS1, I don't know. I think they were 26, but I'm not positive.
03-08-2007, 07:40 PM #7Member
I got a 99 and I thought it was 26 but a know it all friend of mine said 19 I think he' s confused though. I called the dealer but they don't know( imagine that)why don't dealerships know anything?
finally 551 RWHP!!!!
03-08-2007, 07:45 PM #8
Because dealerships are only concerned with seller their NEW cars, selling parts to people overpriced and then getting them to have the dealership work on them, and because dealerships don't know jack about their older vehicles.
03-09-2007, 09:41 PM #9
I believe the 99's were 26's.
05-29-2007, 07:18 PM #10
05-30-2007, 01:26 PM #11
28.8 in 1998
Question: Fuel injectors
By kingls1 in forum General HelpReplies: 46Last Post: 01-30-2014, 10:34 AM -
Fuel Injectors
By SMWS6TA in forum General HelpReplies: 9Last Post: 05-20-2011, 01:05 PM -
Question: 95 LT1 fuel injectors
By 02 Camaro SS SLP in forum Camaro / SSReplies: 1Last Post: 07-28-2010, 05:34 PM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 02:26 PM -
smaller fuel injectors means more fuel?
By Ger-Fire in forum LT1Replies: 5Last Post: 10-12-2006, 03:06 PM
They were 26lb in 1999.
