Thread: P0135 dead end.
    Member staleycornell's Avatar
    Dec 2010
    Memphis
    Black, White
    2001 WS6, 2000 SS Camaro
    P0135 dead end.
    I get in my car, start her up and noticed the MIL light on. I take it to have it scanned and it is the famous P0135 code. I get underneath the car and see no burnt wires, then I check the fuses and they are not blown. I go and buy the Bosch 13111 O2 sensor and install it and the code doesn't go away. Ive tried unhooking the battery and even fuses to reset the ECU to see if that would do the trick. Any suggestions?? Does the car need to go through a few cycles to turn the MIL light off or do I need to have it turned off by a scanner? Or did I even fix the problem? The car has long tube headers and has been tuned by HPTuners last year. Thanks...
    old timer blue02Z's Avatar
    2002 Z28
    Usually disconnecting power to the ecm will extinguish a cel. You need to do some more testing on the harness. Also get it scanned by a testical2 so you can see if it is passing as of now and stored as a history code or if its a current failure
    Dec 2010
    Memphis
    Black, White
    Well ignore this post. I drove it this morning and the light went out after a 1/4 of a mile. I guess it had to go through the cycles.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I would turn it off with a scanner. I had a code PO136 and I replaced the secondary O2 but on the wrong side. I installed the old, good O2 on the correct side and the MIL went out, but when I did a scan, the code was still in the PCM. Cleared and all is well.
    Dec 2010
    Memphis
    Black, White
    I ordered a scanner and should be here in a few days. Thanks for the advice, I will check that out
    2002 Z28
    The code wont clear on its own until after 40 consectutive warm cycles without a repeat failure. It is still stored in your pcm as a history code. The pcm will turn the cel off after 3 consecutive ignition cycles without a repeat failure
    Dec 2010
    Memphis
    Black, White
    Quote Originally Posted by blue02Z View Post
    Thank you sir...I guess it is true that you do learn something new everyday
    2002 Z28
    Quote Originally Posted by staleycornell View Post
    ha!
    that why we are here, give a lil help to others
  1. Help: P0155 & P0135 codes
    By fna7302 in forum Computer & Tuning
    Last Post: 04-09-2015, 08:07 PM
  2. P0135 Help ASAP
    By WS6ICK2K in forum Computer & Tuning
    Last Post: 01-15-2012, 12:20 PM
  3. 01 SS p0135 code-heated o2 sensor!
    By meadowz06 in forum General Help
    Last Post: 10-06-2010, 05:16 PM
  4. Question: Codes p0135 p0155 and p1258
    By buswwa in forum Computer & Tuning
    Last Post: 12-04-2008, 09:51 AM
  5. P0135 code?
    By murray01 in forum General Help
    Last Post: 03-08-2006, 12:50 PM
