Thread: P0135 code?
    Junior Member murray01's Avatar
    Arkansas
    01 z28
    P0135 code?
    It comes up as P0135 02s heater circuit, bank 1 sensor 1 Malfunction. Is this just the o2 going bad or something else? If it is the 02 are the front and back 02's the same?
    Thanks in advanced
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Yes the front and back o2's are the same part number....swap the driverside front o2 with the rear, clear the DTC and see if the new dtc pops up as po420. If it's still p0135 then either you might have bad luck and swap another o2 to the driverside or there's something else wrong. Either way it might take a few drive cycles for any new DTC's to pop up so be patient
    Arkansas
    01 z28
    What does the P0420 mean if it pop's up after i swap them? I have the rear 02's deleted but still have the o2's so i will swap them out and see what happens. thanks for your help.
    Evr sena bdgr killa snak? Roastem's Avatar
    Research Triangle Park, NC
    '99 Z28 M6
    I had the exact same code two weeks ago. It said both O2 heater circuits had went out. I had the guy at Advance remove the code, and price two new sensors. They were like 180 or something for both!
    The code never came back after that though.
    Have the code removed, if it comes back, then replace one sensor at a time.
    Bank 2 sensors are the rear ones, and Bank 1 are the front ones. I think. My computer was tuned to ignore the bank 2 stuff, since there are no cats anyway.
    I think bank 1 sensor 1 is your driver's side front sensor, and bank 1 sensor 2 is your passenger side front sensor.
    Heads 'n Cammed, Moser 12, 3.73's, Weight Reduction, 13" Brembo Kit
    BMR track suspension, full exhaust, the works...
    412whp/394wtq 1/4 mile slip coming soon!
    Gone: '01 Laser Red Cobra 3.73's/Full Bolt-ons
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    I'm pretty sure your right on that. 1 is drivers and 2 is passengers.
    Arkansas
    01 z28
    I have a perdator and cleared them awhile back it took them awhile but the ses light came back on. I think i am going to just try using my back 02 and see if that works.
  1. Help: P0155 & P0135 codes
    By fna7302 in forum Computer & Tuning
    Last Post: 04-09-2015, 08:07 PM
  2. P0135 Help ASAP
    By WS6ICK2K in forum Computer & Tuning
    Last Post: 01-15-2012, 12:20 PM
  3. P0135 dead end.
    By staleycornell in forum General Help
    Last Post: 05-18-2011, 12:19 PM
  4. 01 SS p0135 code-heated o2 sensor!
    By meadowz06 in forum General Help
    Last Post: 10-06-2010, 05:16 PM
  5. Question: Codes p0135 p0155 and p1258
    By buswwa in forum Computer & Tuning
    Last Post: 12-04-2008, 09:51 AM
