Results 1 to 20 of 23
    Apr 2011
    wv
    S.O.M.
    2001 trans am ws6
    bubbling on my '01 trans am
    My '01 trans am is starting to get bubble spots across the top behind t-tops. I hear this is common. My question is how hard is it to fix???
    Member ZeeS7o7's Avatar
    Mar 2011
    Cali 7o7
    2001 Z28
    Quote Originally Posted by '01 ws6 som View Post
    you can't fix it,,, the problem is in the glue that GM started using on 2000 to 2002. My friend has a 1999 and his Z28 is fine so if you can find a 1999 and under and swap it thats your best bet,,,and its a pain in the but to take off to.
    I would just buy another one from 6LE he has them.
    there was a recall but that ended in 2005
    ^^ Agree. Very common problem and the only way to fix it is to replace the panel. I have a new one in my garage awaiting installation. GM discontinued the part late last year.
    Auto Painter RyanJM's Avatar
    Houston, TX
    Usually happens on black from what I have seen the most. I haven't got my hands on one yet to try to fix it. Hoping my friends does it since I have a few ideas I would like to.try. but mostly everyone I know has replaced them. My 98 doesn't have the problem most likely from the different glue as well.as being white and always garaged.
    1998 Trans Am 85k miles.
    02 Trailblazer -Sold
    09 Ram 1500 CC - Sold
    09 Cobalt SS/TC - Sold
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Something different about the T/A's than the Camaro's or is this a problem on all of our cars?
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Problem is common to both.my t/a is bubbling,but that is low on the priority list.
    Posted via Mobile Device
    Apr 2011
    wv
    S.O.M.
    2001 trans am ws6
    Mine is sunset orange metallic, just got it last august and notice a few spots then, now that spring is here I am noticing more. Not high on my priority list either but was just wondering about how hard to fix it. No one will notice it while it is screaming down the road.
    Oct 2009
    The Woodlands/spring/houston
    pewter
    99 trans am
    my pewter t/a is showing signs of it too..but barely
    Big Gulps, huh? HOBS's Avatar
    Idaho
    1999 Trans Am
    You guys sure they only started using the shitty glue in 2000? Mines bubbling and its a 99.
    Oct 2009
    pewter
    99 trans am
    mine is also a 99
    Houston, TX
    Well anyone in the Houston area with bubbles I will give repairing it a shot with a few idea's I have. If it works you pay me if not it's free.
    Last of the Breed j nix's Avatar
    Sep 2010
    Farmington Hills, MI
    2002 Trans Am WS6 NBM
    My 02 WS6 is bubbling on both sides. I thought the previous owner tried to get the area fixed and they did a poor job, guess not. I took it to a body shop yesterday and the guy said that it's the fiberglass and if you fix it, it will just come back.
    Diablo Sport Predator Performance Tune | TB Bypass | Bilstein HD Shocks | Eibach Pro Kit | UMI SFC | UMI Rear LCA's and brackets | UMI adj PHB, UMI Front/Rear Sway Bars |UMI Strut Tower Brace | SLP Lid | SLP Loud Mouth with quad tips | High output alt
    Oct 2009
    pewter
    99 trans am
    fiberglass? i thought those panels were metal...
    Sep 2010
    The manager of Cauley's body shop said it was fiberglass. They do custom corvettes and camaros. They did the Firebreather camaro for the movie Jinn. It looks like a bad ass Trans Am.
    The panel appears to be made out of sheet mold compound (SMC) -- so essentially it is fiberglass.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Thought it was plastic like the front fenders
    024mula 024mula's Avatar
    Dec 2010
    Ohio
    '02 Firebird Formula
    All sorts of pics in this thread of mine: http://www.ls1.com/forums/showthread.php?t=119952
    Dec 2010
    Ohio
    Thanks!
    Mar 2011
    Cali 7o7
    2001 Z28
    Quote Originally Posted by jiveass View Post
    mine is also a 99
    at the end of builds on the 1999 f-bodys before they started on the 2000 cars they switched to this other glue. My friend has a 99 with 215k and its black with not one bubble. U didn't get so lucky
    Quote Originally Posted by RyanJM View Post
    your fine and will not have any bubbling. most 99 are good just got to check the build date and all 98's and under are good.
    a good thread on tech about this with all the info
  1. Bubbling sail panel
    By SS Camaro UK in forum General Help
    Last Post: 11-01-2013, 01:40 AM
  2. need help with bubbling in paint
    By WHITE TA in forum Appearance Section
    Last Post: 02-15-2012, 10:14 AM
  3. Bumper Bubbling How to Paint??
    By GOR1LA in forum General Help
    Last Post: 09-20-2009, 11:14 AM
  4. Bubbling Roof?!?
    By StrikerWS6 in forum Firebird / WS6
    Last Post: 07-10-2009, 07:31 PM
  5. clear coat bubbling?
    By craig02ta in forum Firebird / WS6
    Last Post: 05-20-2007, 02:28 PM
