    Member craig02ta's Avatar
    Indianapolis
    Blue
    04 Silverado
    clear coat bubbling?
    i was wondering if anyone else has had this problem,on my car on the panel between the back window and top on the pass side there is about 5 or 6 bubbles.the car has never been in the sun real bad always stored and garaged.i know it has never had paint work.and there is 1 little one on the bumper.nobody notices it but i know it is there and i hope it does not go any worse. anybody had this problem? thanks
    Robertsdale,Alabama
    99' WS6 Trans-Am
    Ever was the car with dawn or other dish soaps?
    If so that may be the problem..
    Indianapolis
    Blue
    04 Silverado
    i did the zaino process last summer and washed with dawn to begin with once.
    Member Kup98ss's Avatar
    North Carolina
    2002 A4,WS6
    Isn't that still covered under warranty? Or is that just rust?
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Trans ams are common with having this problem on the panel between the window and t-tops. I read on another post that gm covered this with ai believe and don't quote me a 6 year paint corrosion warranty. Ask your dealer. Or if someone else can answer this question........
    Junior Member btaylorSS2001's Avatar
    Allen, TX
    My SS has these bubbles and am just going to get the section repainted...
    I have heard it is a manufacturers defect and could be covered under warranty, if you are still in warranty.
    Look through this thread, its a common problem.
    http://www.ls1.com/forums/showthread.php?t=21339
    Painted manta stripe
    Indianapolis
    Blue
    04 Silverado
    thanks thats alot more than i knew before i had heard nothing about this issue before with other cars. do you think i might still be covered since i am not original owner?
    Member Scanlamp's Avatar
    Colorado
    Black Hardtop
    01 NHRA Formula
    It is not covered under warranty. They cover it as customer courtesy. Some had the cost covered 100%, some as low as 50%-50% split. Just depends on the regional rep you get. I had to pay $200 deductable. The only problem may be that you are not the original owner. Take to a dealer and start there. Take a copy of the TSB. They ussually try to deny the problem is a defect and that there is no TSB.
    Do not just have it painted. This will not solve the problem. The problem seems to be in the glue they used.
    Good luck to you.
  1. clear coat seperating
    By YellaVette3 in forum Showcar and Detailing
    Last Post: 06-21-2014, 05:21 PM
  2. Question: WS6 wheel clear coat
    By hardmanws6 in forum Appearance Section
    Last Post: 08-13-2013, 12:25 PM
  3. clear coat help..
    By 98maro in forum General Help
    Last Post: 08-09-2012, 12:50 PM
  4. fly landed in the clear coat
    By qwik219d9 in forum Showcar and Detailing
    Last Post: 04-16-2009, 07:44 AM
  5. Clear Coat
    By flipsutter in forum Appearance Section
    Last Post: 03-07-2009, 05:19 PM
