04-18-2011, 08:50 PM #1Junior Member
- Apr 2011
- texas
white- 99ta
A good cam for ported 241 heads?????
There are some 241 heads ported couple years ago by MTI in houston. The guy selling them does not know the #s that it made after they were ported but he was using an mti x1 cam w/ those heads and was making 400 rwhp.. All the port work compared to 243 stock look way better and bigger ports... Any info. on some good cams would be appreciated.. Thanks
This is the current set up on my car
98TA
pace setter long tube headers
3" y pipe
stock intake
stock heads
2800 stall
4.10 gears
dyno 329hp/341trq
12.4 @ 108mph mt drag radials
*** new to the site still figuring out where to post**
05-10-2011, 05:17 AM #2
A 228 cam would probably make you happy and work good with those heads. You also might look at going with a higher stall, maybe 3,500-3,800....when I was running a 220/224 with a 2,800 stall you could hear it at the track when I got up into the powerband after the stall was locking up. Swayed my stall for a 3,800 and it made a world of a difference
05-14-2011, 04:04 PM #3Junior Member
- Sep 2010
- Ohio
midnight blue- 1998 Pontiac trans am
I don't think the heads and cam will be as much of a benefit without a better intake. At least an ls6.
05-14-2011, 07:38 PM #4Bad habbit- Smoking Fords
- South Florida
Sunset Orange Metallic- 2001 Camaro SS
05-28-2011, 12:53 AM #5
By 99whiteta in forum General HelpReplies: 0Last Post: 04-18-2011, 07:37 PM -
806 heads, ported??
By SSMuscle in forum Internal EngineReplies: 8Last Post: 05-31-2010, 12:56 PM -
AFR heads VS. Ported and beefed up stock heads.
By hutcher04 in forum Internal EngineReplies: 10Last Post: 03-14-2010, 08:27 AM -
F/S Ported 6.0 heads
By knappo_99 in forum Parts For Sale / TradeReplies: 15Last Post: 07-30-2008, 04:59 PM -
AFR heads vs Patriot Heads.. CNC ported
By WARP211 in forum Camaro / SSReplies: 6Last Post: 03-01-2007, 08:51 AM
