    GROUND KONTROL C.C. CEO SSMuscle's Avatar
    Apr 2009
    Dallas, Texas
    PEWTER
    2002 Camaro SS
    806 heads, ported??
    What is the number "806" mean?? I have a friend saying he's selling some ported heads 806, but i'm a noob. What is the diff. between the numbers.
    12 SECOND CLUB FASTEDDIE Z's Avatar
    Oct 2009
    Brick N.J.
    1998 Z28 [email protected]
    Quote Originally Posted by SSMuscle View Post
    806 is the casting # of the heads . Its on the front corner . 806 is the worse flowing LS1 head and has perimeter valve cover bolts .They came stock on the 98-99 F bodys . 241's are a little better . I believe they came on 00-02 . 243's are the best of the 3 . 243's in stock , untouched form will add @ 20-25 RWHP over 806's and 241's.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Actually 806 perimeter bolt heads were only used in 1998 on F-bodies. 241's are the center bolt heads for LS1's. 243's are center bolt and were used on the Vette LS6 engine (along with a different cam).
    Apr 2009
    Dallas, Texas
    PEWTER
    2002 Camaro SS
    I see.......thanks. So even though these 806 are ported, they are not better than stock heads on a 2002 ls1?
    Member Speed_kills_WS6's Avatar
    Feb 2008
    Anderson, SC
    2002 TA WS6 M6
    The best place for 806 heads is a scrap yard. Save the money towards 243s. However, with a stock cam , it won't add 25hp.
    Apr 2009
    Dallas, Texas
    PEWTER
    2002 Camaro SS
    Thanks guys. I'll save my money.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    You guys are misinformed.
    The 806 heads are `97-98 model year specific but are not as bad as people say. In fact the biggest difference is the perimeter bolt valve covers. They were cast differently then the later heads but still have the same port and chamber volume as any other LS1 head. And if there are any flow differences in stock form you would never feel it.
    Also any ported head including the 806's is still better then stock.
    BTW
    `97-98 heads = 806
    `99-00 heads = 853 *
    `01-02 heads = 241
    * some 241's may be found on late production `00 cars
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Apr 2009
    Dallas, Texas
    PEWTER
    2002 Camaro SS
    So 806 (PORTED) will flow better than stock?? Hmm......good to know. 150$ sound like a good deal on some 806 ported heads?
    `98 Formula M6 HdTp
    Yes any ported heads are better then any stock head.
    The problem lies in that you have to get perimeter bolt valve covers (which will be an added expense) too use them. Also the Coils mount directly to those valve covers (no coil brackets required).
  1. 799 Ported Heads ONLY on an LS1
    By BBATCAR in forum Internal Engine
    Last Post: 09-06-2013, 07:57 PM
  2. AFR heads VS. Ported and beefed up stock heads.
    By hutcher04 in forum Internal Engine
    Last Post: 03-14-2010, 08:27 AM
  3. LS1 Ported Heads
    By 94 Formula in forum Parts For Sale / Trade
    Last Post: 10-25-2009, 08:55 PM
  4. F/S Ported 6.0 heads
    By knappo_99 in forum Parts For Sale / Trade
    Last Post: 07-30-2008, 04:59 PM
  5. AFR heads vs Patriot Heads.. CNC ported
    By WARP211 in forum Camaro / SS
    Last Post: 03-01-2007, 08:51 AM
