    Fear The Reaper IceeWS6's Avatar
    Asheville, NC
    Pewter Metallic
    '02 WS6 M6 - The Reaper
    Alternator issues. again.
    So my alternator went out today. for the second time. just stopped charging. belt has tension, alt is turning, etc. first one went bad on the dyno. cyrrent alt is reman model.
    is this a common problem with these cars? if so, why does it happen and how can i prevent it?
    02 ws6, lq9 stroker.
    also, would underdrive pulleys affect this?
    Asheville, NC
    Pewter Metallic
    if i had looked at current threads i could have answered my own question lol.
    my power steering pump is slightly leaking, which in turn has ruined my alternator. yay, two parts to replace/fix. ugh.
    '02 Pontiac Trans Am WS6 M6
    550rwhp 480rwtq
    more on the waaay
    Orlando, FL
    Mean Black
    glad you figured it out.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    make sure the pump is leaking before you replace it,the ps hose leaking is much more common.also check rockauto .com for parts,they have quality parts and low prices.
    Posted via Mobile Device
    I got a couple of stickies in the General section that may help you. Could be a 0.80 cent O-ring.
    As far as the alternator try using some electronic cleaner to get some of the fluid out. It may still be salvageable.
  1. Bad alternator solved my years of issues
    By rotwiler in forum Camaro / SS
    Last Post: 10-15-2012, 05:17 AM
  2. What can cause my alternator to do this?
    By Firebirdformula in forum Stereo and Electronics
    Last Post: 07-04-2010, 06:00 PM
  3. Question: Alternator MAJOR ISSUES! Please help at mywits end
    By TrickedOutSS in forum General Help
    Last Post: 06-17-2009, 11:25 AM
  4. Alternator issues - excitor wire reading 10V
    By 01 SS Vert in forum External Engine
    Last Post: 03-27-2009, 02:26 PM
  5. alternator
    By a10beav in forum GTO
    Last Post: 09-26-2006, 08:39 AM
