Results 1 to 10 of 10
    Jun 2009
    Denver, Colorado
    Angry Alternator MAJOR ISSUES! Please help at mywits end
    Hi everyone,
    I'm new to Ls1.com although not new to Ls1's nor F-bodies. Here's the thing, I'm taking my car out of winter storage, at the end of last season, It had let me sit, the Alt. wasn't throwing a charge and It let me sit on the side of the road.
    Well, today I took the battery and Alternator to Checkers and had them both scanned. The Battery was bad, which I knew but, the Alt. also came up after being scanned 5 times as bad. So, I replaced the battery and Alternator today, installed everything correctly and how it was when I took it out. NOTHING! The battery is throwing 12v, but I am getting absolutely nothing from the Alternator. No charge what-so-ever.
    I am at my Wits end here. I worked all day, after working a 12 hour grave yard shift to get this car running, and I am at a loss. does anyone have a clue what could be the deal?
    Additional Information: I have a Stereo System that has a different than stock battery terminal on the +. Other than that, nothing has changed as far as the Power Supply goes.
    Please help in any way possible, or if anyone has had the same issues
    Thank you!
    Jordan
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    It's possibly you got a bad alternator from
    The parts store
    Member NaviDyn's Avatar
    Dec 2008
    St Louis
    Tan
    2002 GMC Yukon
    Remans from parts stores are hit and miss. Even at Napa, whom isn't a low cost seller like CSK or Autzone.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by NaviDyn View Post
    To the point I wonder why no one bothers to have them tested before they leave the store.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    I wonder if the guage is bad? That would prevent charging..
    Quote Originally Posted by rbob93 View Post
    seems like they are a 50/50 shot... truck that i used to have i went to the parts store 3 damned times because of the alternators being bad taht they sold me... poor guy at the store felt bad for me and gave me a half price discount since i went there 3 times... (it was a napa btw)
    Work..Eat..Sleep..Repeat nut6778's Avatar
    Bethalto, IL
    Sunset Orange Metallic
    2002 Z28
    I just went through this same thing about a month ago.
    I replaced the Alt and Bat, then on my way to work, my lights went out. After being towed home, I pulled the Alt back out and it tested bad (btw...this one was new, not a reman).
    You can also check the small wire on the harness that clips to the back of the Alt. If you stretched that wire at all when taking out the Alt, it will break...trust me. I ended up extending that wire on mine.
    Jun 2009
    Denver, Colorado
    Oh we had it tested at the parts store.... three times, and it was good.
    Bethalto, IL
    2002 Z28
    I would check the red wire and the connector then. I pulled on mine just a little while trying to get in a position to disconnect the connector, thus pulling the wire out of the connector. I ended up taking the connector apart and soldering in a new, longer wire.
    Jun 2009
    Denver, Colorado
    ok thank you!
  1. Bad alternator solved my years of issues
    By rotwiler in forum Camaro / SS
    Last Post: 10-15-2012, 05:17 AM
  2. Help: Major issues with my car
    By bpopham22 in forum General Help
    Last Post: 04-16-2011, 10:42 AM
  3. Alternator issues. again.
    By IceeWS6 in forum External Engine
    Last Post: 04-08-2011, 05:30 PM
  4. Question: Has anyone had major issues with headlights??
    By CTA2002WS6 in forum Firebird / WS6
    Last Post: 07-19-2010, 11:01 AM
  5. Alternator issues - excitor wire reading 10V
    By 01 SS Vert in forum External Engine
    Last Post: 03-27-2009, 02:26 PM
