Results 1 to 13 of 13
    Member Firebirdformula's Avatar
    oklahoma
    2000 firebird formula Ws6
    What can cause my alternator to do this?
    When i first start my car in the morning my charging gauge stays low and will stay low until i rev it to 2k rpms and then when i drive it drops once and then charges fine throughout the day ?
    Nov 2009
    Jacksonville FL
    TRIPLE BLACK
    2000 CAMARO SS M6 #2100
    Do you have under drive pulleys? They cause your accessories to turn at a lower rate which can cause this. When revving at a higher rpm, they are turning more at the speed they are supposed to therefore charging it back up. Unless you keep it at a higher rpm for long enough for it to charge right then the juice will fall back down.
    oklahoma
    no everything is completely stock....and when i rev it to 2k and let off somethin kicks it on because the engine goes under a load it sounds like, and the rpms drop jus a little
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Free bump in hopes a mod might see this and move it to the appropriate section of the forum where you might see more responses. Not too many people troll the stereo and electronics section. You probably want to shoot for external engine or something along those lines.
    oklahoma
    ok man thanks ill move it
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Take the alt. off and take it up to the auto parts store and have them test it. Unless you have one already...
    rsg98Z28 rsg98Z28's Avatar
    Atlanta, GA
    1998 Camaro Z28 vert
    sounds like the voltage regulator, its on the alternator usually when the regulator goes bad u need to replace the entire alternator
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Quote Originally Posted by rsg98Z28 View Post
    I second the regulator.
    Just change the regulator and even change the bearings while your in there. You will thank me as I should have taken my own advice as I am now on my 4th one from the parts stores.
    oklahoma
    ya i took my alternator back to the guy who rebuilt it and he fixed it for free, and on the way home i teated it at oreillys haha three times jus to make sure when i put it on for the 5th time now!!!!!!! it woruld woprk, and everything is workin i revved it to 4 grand and it didnt drop at all
    Member qwik219d9's Avatar
    Sep 2008
    Atlanta, GA,Ft.Walton Bch,FL
    Blog Entries
    1
    99 ws6
    alt.
    from what I've read about alternaters when it stops charging replace the alt.
    w/ a brand new alt.
    w/ rebuilt plan on continuosly replaceing fquently.
    Atlanta, GA
    Quote Originally Posted by qwik219d9 View Post
    w/ a brand new alt.
    I agree!!
    Pittsburgh
    2008 Hummer H3
    w/ a brand new alt.
    I agree!!
    +3
    May 2010
    Ohio
    2000 T/A WS6
    my altenator does the exact same thing I keep an eye on it through out the day. I just replaced the battery because the last one just died on me so I might need to replace the altenator next I think like 14v is charging? and sometimes it stays just a hair above 13 for a long time
  1. Alternator help
    By GOHOME! in forum General Help
    Last Post: 06-06-2009, 11:18 AM
  2. Need Help With Alternator!!
    By camarossf650 in forum General Help
    Last Post: 03-20-2009, 05:42 AM
  3. Alternator Help
    By Chamelion WS6 in forum General Help
    Last Post: 12-16-2006, 08:13 AM
  4. alternator
    By a10beav in forum GTO
    Last Post: 09-26-2006, 08:39 AM
  5. lt1 ALTERNATOR
    By drb131s in forum Parts For Sale / Trade
    Last Post: 09-17-2006, 04:16 PM
