Results 1 to 20 of 26
Thread: e-brake handle
03-31-2011, 08:34 PM #1Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
e-brake handle
ok guys,, is time to get it fixed..
about a month ago i took my car to the shop, and the idiot on the tow truck messed it up..
it brakes and everything but it doesnt stay up, i tried to fix it but, it didnt work. i think i have to replace the handle, where can i buy it or how can i get it fixed?
thanks 4 the help00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
03-31-2011, 08:58 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
Junkyard is where i would start
Did you pull the center console out too see if its damaged?
03-31-2011, 09:06 PM #3Electrical Engineer
- Jul 2009
- North of the Motorcity
1. junkyard
2. craigslist
3. here
4. eGay
Are the gears worn? Spring worn out?
03-31-2011, 09:40 PM #4Senior Member
- Feb 2010
i removed the center console.. the gears seem to be fine,, is just the guy pulled it out to hard and the whole handle came off, and the little button on the end,, so theres no way to get it fixed, is it really hard to swap it out?
its a pain the ass to take the center console off
03-31-2011, 09:55 PM #5Electrical Engineer
- Jul 2009
When the handle and button got ripped out, he took the mechanism that latches onto the gear with it?
I've never swapped the whole thing, so sadly I have no experience input on that. I would imagine that taking the center console apart would be the most difficult.
03-31-2011, 10:10 PM #6Senior Member
- Feb 2010
its kinda hard to explain exactly whats wrong with it,, but when the center console is off and u pull it up, to hold it up you have to put the locker manually,, i use a screw driver or something similar..
whe you pull the ebrake on ur car it stays up by it self,, to put it down thats when you push the botton on the end of the handle,
on mine u pull it up, and it goes back down again unless you put the locker on the gears manually..
damn i hope some 1 can understand what i just type,,lol..
03-31-2011, 10:18 PM #7
Why isn't the tow guy getting it fixed 4 you?
I replaced one on a Toyota once and the gear and locking mechanism were septate so that was an easy fix, but sorry no experience on this. Is your handbrake after market?
03-31-2011, 10:53 PM #8
04-01-2011, 04:37 AM #9Senior Member
- Oct 2008
- Coral Springs, Fl
Is there any way you can show this though pictures or maybe a video? Sounds like the spring to me
04-01-2011, 08:17 AM #10
04-01-2011, 08:27 AM #11
I have the whole e-brake unit for sale. Let me know if you need it. But it does sound like just the spring to me.
04-01-2011, 09:47 AM #12
04-01-2011, 10:53 AM #13
You would'nt want the tow truck guys to fix it, they probally brake something else trying to fix the e-brake.
It sounds like a spring or something like that came lose or disconnected.
Best of luck.
04-01-2011, 01:32 PM #14
I will think the worse part is to remove the center console. I removed mine recently and it takes some twisting and patience to get out. I will say to chekc the spring like others said or find you a another E brake assembly.
04-01-2011, 05:54 PM #15
04-01-2011, 05:57 PM #16
04-01-2011, 06:00 PM #17
04-01-2011, 06:02 PM #18Senior Member
- Feb 2010
ill post some pix later on... or ill try to post a vid guys,, but ill have to take the vid from my phone,,lol
04-02-2011, 09:53 PM #19
04-03-2011, 05:57 AM #20Senior Member
- Oct 2008
- Coral Springs, Fl
can you remove the center console? It might be hard to with the ebrake not staying up but you need to look at the internals of it.
E-brake handle prob
By eruditegearhead in forum GTOReplies: 3Last Post: 08-16-2010, 09:37 AM -
Question: metal part on e-brake handle really hot, normal??
By ggino85 in forum LT1Replies: 3Last Post: 09-16-2009, 08:34 PM -
e-brake handle
By BigDB in forum Camaro / SSReplies: 0Last Post: 08-10-2008, 09:45 AM -
Question: Parking brake handle removal
By TIMBO0566 in forum GTOReplies: 6Last Post: 05-19-2008, 12:28 AM -
WTB:e-brake handle
By firehawk139 in forum Parts Wanted / TradeReplies: 1Last Post: 10-03-2006, 09:10 PM
