Thread: E-brake handle prob
08-12-2010, 01:34 PM #1
E-brake handle prob
The ratchet mechanism on the e-brake handle on my 04 recently stopped working. I can pull the handle up and the brake holds but, the handle won't remain there. Anyone had this problem ? If so, what was the fix ? Any specific tricks to disassembling the console to access the mechanism ?
Thanks in advance for any help.
KB
08-13-2010, 03:35 PM #211 years of bangin gears
- Jan 2009
- North Jersey
The handle won't stay up when you use the e-brake? You're gonna need a new handle. A few months ago my car used to slowly roll down my driveway with the e-brake on. Tuned out the previous owner replaced the rotors all around and never adjusted the e-brake shoes, causing me to pull the lever all the way up. My manager and I adjusted the rear shoes and I found the adjustment bolt on the e-brake handle(under rubber boot on e-brake handle between console and pass seat) and I am good to go now.
08-15-2010, 05:03 PM #3
http://www.dlcparts.com/images/99-3528.pdf
here you go, try this link, its for radion installation, but should help you get to the E-brake easier....or you can take the passenger seat out and pull back the rubber cover over the brake
08-16-2010, 09:37 AM #4
Do not go out and buy a new handle. This is a really easy fix.
Just pull the silver portion off, from the back of the handle, just pick it straight up and slide it forward off the button. next pull the boot off..
There is two bolts, a nut and a connector you must remove to get the handle out of the car.
Then you will notice a white nylon piece, that attaches to the button, and goes down to a piece that connects to the teeth.
What happens is the piece will wear out, and come out of the clip area.
Drill a hole in the plastic piece where it slides into the bracket, either zip tie or use safety wire and reconnect it and secure it back in place. Once you do that, it will never break again.
There is a actual write up on some other GTO forums that have pictures.
--Scott
Help: e-brake handle
By 98maro in forum General HelpReplies: 25Last Post: 04-14-2011, 12:00 AM -
Question: metal part on e-brake handle really hot, normal??
By ggino85 in forum LT1Replies: 3Last Post: 09-16-2009, 08:34 PM -
e-brake handle
By BigDB in forum Camaro / SSReplies: 0Last Post: 08-10-2008, 09:45 AM -
Question: Parking brake handle removal
By TIMBO0566 in forum GTOReplies: 6Last Post: 05-19-2008, 12:28 AM -
WTB:e-brake handle
By firehawk139 in forum Parts Wanted / TradeReplies: 1Last Post: 10-03-2006, 09:10 PM
