Results 1 to 17 of 17
Thread: Coolant Leak.
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Coolant Leak.
    I have a coolant leak someone in the back of the motor. Its not the block off crossover pipe plugs and it looks like its coming from the passenger side. I had it jacked up and running but I didn't see anything leaking. but there was a drip from somewhere.
    Where else can I check?
    Heater core - Is your passenger side carpet wet?
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Also possible heater hoses or heater hose pipes.
    Here's a decent sticky on the subject
    Orlando, FL
    Mean Black
    lol i guess is heater hose season. Let me know if you have any questions about the heater hose.
    Orlando, FL
    Mean Black
    check the 2 hoses that come in by the firewall to the heater hose.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Passenger side carpet is dry, I only let it run for about five minutes but I couldnt feel a drop. Is the heater core towards the center of the car? Its the center passenger side of the car because the coolant drip is dripping off the bottom corner of the oil pan.
    There is also smoke coming out around where those hoses are when I rev it but i cant really tell below that. Its not the head that's leaking and I don't think that's whats letting the smoke.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    [ame]http://www.youtube.com/watch?v=rg6Fg_DJa14[/ame]
    Orlando, FL
    Mean Black
    is kinda of hard to tell on the video. You sure the smoke is not oil burning on the exhaust manifold? also can you post a few pics of were you are having the coolant leak?
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    I will tonight. We took a pressure tester to it last night and I actually have two. One is off of a water pump hose and the other from the back is still tbd
    Orlando, FL
    Mean Black
    Quote Originally Posted by jetaws6 View Post
    the only thing i can think on the back of the engine is the crossover coolant pipe. pics will help out.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Well I tried to go a picture this weekend but you cant really see anything. All's I know is its running down and dripping off of the back corner of the oil pan. Gonna pull the intake off tomorrow just to verify that its not the block offs but I am at a loss of what it could be. I might just take it to a shop.
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Took a little vid hopefully this helps
    [ame]http://www.youtube.com/watch?v=JkV-k1-SA9A[/ame]
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    Passenger side is dry to
    Madison, WI
    2001 Silverado Z71
    I can't even watch that video. Makes me dizzy and nauseous.
    Maybe the coolant froze and cracked the block?
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    It looks like it might be a head bolt.
    Orlando, FL
    Mean Black
    yeah is kinda of hard to look at the video. it looks like that movie cloverfield. Is from the passenger side correct. Did you check the block drain? like cutlass said it could be the head gasket too.
    Apr 2011
    syracuse ny
    2000 trans am
    Had the same issue. It turned out had a pin hole in my heater hose.
  1. Help: big coolant leak can't see from where?!
    By ls1fan74 in forum GTO
    Last Post: 03-25-2015, 01:54 PM
  2. Help: Coolant Leak
    By maher19403 in forum GTO
    Last Post: 10-22-2010, 01:09 PM
  3. Help: big coolant leak
    By Siciliano15 in forum External Engine
    Last Post: 05-03-2010, 01:31 PM
  4. Coolant Leak
    By Tx98Formula in forum General Help
    Last Post: 04-03-2010, 08:50 AM
  5. Help: Need pic of coolant pump weep hole (Coolant Leak)
    By Sweet Chops in forum General Help
    Last Post: 04-20-2009, 07:14 PM
