Results 1 to 10 of 10
    Member Siciliano15's Avatar
    NY/CT
    1998 Trans Am WS-6
    big coolant leak
    is there a certain problem area with these ls1's where they leak coolant from a certain area? i have a 1998 trans am and it all of a sudden one day started leaking a lot of coolant. i tried to find where it was leaking from and it seemed to be from the water pump area. it seemed to be running off the bottom of the water pump even with the car not running every time i would top off the radiator. im not sure if it was from a gasket or from the front of the water pump but if you were me what would you do? wat is the best replacement water pump and should i replace it?
    Member Sas's Avatar
    Loveland/Ft. Collins, CO
    Blue
    2001 Formula Firehawk
    Sounds like your water pump's on it's final legs, I just replaced mine and the leaking stopped. When I pulled mine I noticed the gasket was shot, so I just replaced everything, to save the hassle of having to tear it all apart in a couple months. I think you have an LT1 if I remember the years right and first thing I'd do is pull it out and see if the leaks coming out of the hole on the bottom. That's the first sign it's shot. I don't remember if you can see the weep hole without pulling it out on earlier years.
    Nevermind, just looked and you have a LS1, so no weep hole on the bottom.
    NY/CT
    1998 Trans Am WS-6
    i did see a tiny hole but i didnt notice any water coming out of it. would u go with a stock replacement or an ls6 one? i was on ws6 store.com and saw they have an edelbrock one and an electric powered one. which one would be the best?
    Bragg NC
    Met. Sunset Orange
    01 SS
    Stay away from electric if its a Daily Driver, A stock replacement will do just fine.
    Under the neck of the water pump there is a "weep" hole that allows coolant to flow out when the seals go bad internaly on the pump. I would either rent or purchase a cooling system pressure checker to pin point the cause of your leak. All you do is connect it to the neck of the radiator and pump it to add pressure to the system and find your leak. Alot of parts stores rent them now, its easier to find the leak rather than replace the pump and find out it was just a hose.
    J
    Quote Originally Posted by sunsetorangess View Post
    J
    Junior Member xTAWS6X's Avatar
    Apr 2010
    Muncie,IN
    1998 WS6
    My 98 TA did the same thing man. I pulled the pump and found out the lower factory gasket had blown. Since my car had been running kinda hot as of late I went ahead and replace the waterpump and thermostat. It's simple to do, the water pump was 133.91 and the thermostat i got was a Mr. Gasket 160 degree, after shipping it was 17.86.
    NY/CT
    1998 Trans Am WS-6
    dont even need a pressure tester. i pour water in the radiator and it drips right out under the water pump. went to advance auto and ordered a new asc stock replacement water pump also around $133 and got two felpro gaskets to go with it and a felpro thermostat gasket. should be in by tuesday they said.
    Senior Member
    texas
    2000 formula
    just change it.......and t stat........and hoses............problem solved
    Apr 2010
    Muncie,IN
    1998 WS6
    Quote Originally Posted by sjsingle1 View Post
    Thats what I did
    NY/CT
    1998 Trans Am WS-6
    t-stat is like 3 months old so thats ok. gonna change the pump for now and see what happens. gonna be changing heads in about 2 months so ill change the hoses then.
  1. Help: big coolant leak can't see from where?!
    By ls1fan74 in forum GTO
    Last Post: 03-25-2015, 01:54 PM
  2. Coolant Leak.
    By jetaws6 in forum General Help
    Last Post: 04-07-2011, 04:39 AM
  3. Help: Coolant Leak
    By maher19403 in forum GTO
    Last Post: 10-22-2010, 01:09 PM
  4. Coolant Leak
    By Tx98Formula in forum General Help
    Last Post: 04-03-2010, 08:50 AM
  5. Help: Need pic of coolant pump weep hole (Coolant Leak)
    By Sweet Chops in forum General Help
    Last Post: 04-20-2009, 07:14 PM
