Results 1 to 10 of 10
Thread: Coolant Leak
    Junior Member maher19403's Avatar
    Sep 2008
    Norristown,PA
    2005 GTO SAP/GXP 1 of 286
    Post Coolant Leak
    about 2 weeks ago i was driving my 05 GTO to a car show i pulled behind a vette so i smell coolant i stop i did see coolant leak around the water pump/crank shaft pully i took it to the dealer they did not find nothing wrong with it they sad no leak fund i'm not crayz ??? know it's leakimng more no idea where it's coming from Coolant TEMP is normal 188 to 197
    help
    thanks.
    Sep 2008
    Norristown,PA
    Quote Originally Posted by maher19403 View Post
    help
    thanks.
    it only have 56k
    Mar 2010
    Oak Lawn/ Chicagoland
    Yellow
    2004 GTO
    Make sure the surge tank cap is not hold pressure cause my GTO had a smell at times and it was the capseal was bad try that
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    If you saw a leak near the water pump/crankshaft, then the pump is on its way out.
    Sep 2008
    Norristown,PA
    Quote Originally Posted by andyramsaran View Post
    it's not holding pressure ???
    i hope nothing major
    thanks
    Sep 2008
    Norristown,PA
    i hope so thanks
    Junior Member MNGTO's Avatar
    Minneapolis, MN
    2004 GTO
    it should hold pressure.
    footbrake racer racer426's Avatar
    Jan 2008
    antioch,tn
    2004 gto
    Put a pressure tester on it and look for the drip
    Don't be a dumb ass Damage Inc.'s Avatar
    Baltimore, Md.
    Brazen Orange Metalic
    '06 GTO
    The dealer most likely could not find it because they didn't fully warm up the engine before testing. Sometimes they only leak when they're hot. As stated above if you saw coolant on or around the pulleys it's most likely the pump. Very easy DIY.
    Junior Member miltrez's Avatar
    Aug 2010
    Yukon, OK
    Pulse Red
    2004 GTO
    Any LOW COOLANT warnings on dash?
  1. Help: big coolant leak can't see from where?!
    By ls1fan74 in forum GTO
    Last Post: 03-25-2015, 01:54 PM
  2. Coolant Leak.
    By jetaws6 in forum General Help
    Last Post: 04-07-2011, 04:39 AM
  3. Help: big coolant leak
    By Siciliano15 in forum External Engine
    Last Post: 05-03-2010, 01:31 PM
  4. Coolant Leak
    By Tx98Formula in forum General Help
    Last Post: 04-03-2010, 08:50 AM
  5. Help: Need pic of coolant pump weep hole (Coolant Leak)
    By Sweet Chops in forum General Help
    Last Post: 04-20-2009, 07:14 PM
