Results 1 to 14 of 14
Thread: need a parts list
02-14-2011, 06:10 AM #1
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
need a parts list
i need input. I need a list of everything to lower my car properly. Keep in mind that i am on a budget. but i do want good stuff.
02-14-2011, 07:35 AM #2
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Depending on how much is your budget.
You could get koni shocks and stranos. That's over $1000 plus you need adj. Panhard bar.
To lower it properly u also need relocation brackets,
And lower control arms.
That's another $500.
So it would be around $1500 just in parts.
Or get bilsteins shocks for $400 and everithing else I said.
But it depends how much u want to spend.00 ss blk m6 " STOCK" strano springs, slp bilstein shocks, adj LCA, adj panhard bar, relocation brackets, 2 point SFCs welded,OEM zo6 rims black, magnaflow exhaust, CME exhaust,E/cutout, slp grille, custom front plate mount, HIDs, whistler mod, side moldings delete, slp air lid, ported and polished TB, strut tower brace, 3.73s gears, and some other parts to list!
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
02-14-2011, 08:52 AM #3
- Oct 2009
pewter- 99 trans am
holy shit...thats a lot....but ive spent 2500 in the last month on it, so whats another 1500.....
02-14-2011, 08:56 AM #4
02-14-2011, 11:07 AM #5
02-16-2011, 03:48 PM #6
you should also get relocation brackets and adj torque arm. Adj. LCA wouldnt hurt as well.
02-16-2011, 03:50 PM #7
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
look through this thread. this should answer every question. http://www.ls1.com/forums/showthread...le+panhard+bar
02-20-2011, 07:38 PM #8
- Oct 2008
- New Brunswick Canada
Black- BLK TA modded 12.2@113mph
Panhard bar and lca what to do
I'm loooking at different sites and UMI and BMR seems to be the product mostly used. I ordered a Yank SS3200 and I'm thinking these 2 pieces should probably follow but I see them at $89 to a lot more non adjustable single adj. dual adjustment
What is a decent set that will work well and will not cost me an arm and a leg? Some people say just buy the non adj. it is a lot better than my stock stuff I'm running 295/36/18's on a 10.5" rim 56mm offset what do you guys think?
Since I'm not lowering the car anytime soon should I even bother changing these yet and what will it do for me if I do? I'm being told that it might be a good idea to change but I'm not 2 sure why????Last edited by Durango; 02-20-2011 at 07:47 PM.
02-21-2011, 11:32 AM #9
- San Diego
Silver- 02 Camaro Z28
IF you don't have oversided rims you'll NEED lowering springs and a good set of shocks. If you have bigger rims then you'll want to do an adj panhard bar or install and take a look and see if you want to spend the coin.
I did not get a panhard par, no LCA's or relo brakets or or or...just springs and shocks and she drives like a champ. My wheel hop is 95% gone (used to wheel hop VERY badly when stock).
02-21-2011, 11:51 AM #10
- Oct 2008
- Coral Springs, Fl
Don't forget an adjustable torque arm
02-21-2011, 12:49 PM #11
- Oct 2009
pewter- 99 trans am
ok so if i get just shocks and springs, it will be ok? i have 18x10.5s out back and 17x9.5s up front...
02-21-2011, 01:21 PM #12
02-21-2011, 07:21 PM #13
You will want an adj panhard rod regardless of tire/wheel size to recenter the rear like already mentioned. The relocation brackets and adj torque arm will help re-establish angles to prevent wheelhop and improve traction.
Durango, I would get all adj. so you do not have to rebuy stuff later down the road when you decide to lower.
02-22-2011, 07:26 PM #14
i know people that cut there stock springs and used there stock shocks and like the ride/look...if you dont have the money to waste mike
parts list please
By jodmari in forum General HelpReplies: 8Last Post: 08-15-2013, 08:59 AM -
408 Stroker parts list...
By My00Z28 in forum Internal EngineReplies: 40Last Post: 10-24-2010, 09:42 PM -
parts list for approval
By jiveass in forum Internal EngineReplies: 3Last Post: 01-31-2010, 07:00 AM -
parts list
By Colten W. in forum Internal EngineReplies: 28Last Post: 07-30-2008, 10:57 PM -
WTB: Parts List
By Stu's '00 Z in forum Parts Wanted / TradeReplies: 11Last Post: 12-13-2005, 06:20 AM
