Thread: parts list for approval
01-30-2010, 07:12 PM #1its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
So im puttin another 350ci engine in the vette, and here is the parts list of what im gonna get...unless you guys see something thats not going to work. any suggestions are welcome.
Cam-Comp Cams thumpr 279th7
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 2,000-5,800
Intake Duration at 050 inch Lift 227
Exhaust Duration at 050 inch Lift 241
Duration at 050 inch Lift 227 int./241 exh.
Advertised Intake Duration 279
Advertised Exhaust Duration 297
Advertised Duration 279 int./297 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.479 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.465 in.
Valve Lift with Factory Rocker Arm Ratio 0.479 int./0.465 exh. lift
Lobe Separation (degrees) 107
Camshaft Gear Attachment 3-bolt
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Grind Number 279TH7
Summit Racing 1.5 ratio roller rockers
Summit racing valve spring and retainer kit
Holley 750cfm 4160 adjustable float carb
Weiand 8150 stealth intake manifoldLast edited by jiveass; 01-30-2010 at 07:15 PM.
01-30-2010, 07:48 PM #2Member
- Jun 2009
- coon rapids, MN
red- 2000TA
is this a sbc or gen 3 /ls motor?
01-30-2010, 09:55 PM #3
01-31-2010, 07:00 AM #4Member
- Jun 2009
- coon rapids, MN
red- 2000TA
remember to run the right oil to brake in the cam.I like the elderbrock AIR-GAP ,made more power in a intake shoot out in chevy hi-proformance.run plastic carb spacer ,and make a air pan to take the cool air from in front of the radiator . a 2x3 sheet of aluminum works.I see good results with the compcam Xtreme energy cams also.run a good HEI dist. also. I have a 80 vette with a 427 sbc,3000lbs stiff springs.
parts list please
By jodmari in forum General HelpReplies: 8Last Post: 08-15-2013, 08:59 AM -
Help: need a parts list
By jiveass in forum Suspension and HandlingReplies: 13Last Post: 02-22-2011, 07:26 PM -
suspension shopping list, approval needed
By bpopham22 in forum Firebird / WS6Replies: 32Last Post: 03-09-2010, 06:21 PM -
parts list
By Colten W. in forum Internal EngineReplies: 28Last Post: 07-30-2008, 10:57 PM -
WTB: Parts List
By Stu's '00 Z in forum Parts Wanted / TradeReplies: 11Last Post: 12-13-2005, 06:20 AM
