Results 1 to 15 of 15
    Pa
    Talking New Product! 98-02 LSX Solid Aluminum Motor Mounts from UMI
    Solid Aluminum Motor Mounts for the 98-02 Camaro/Firebird LSX Engines
    Part #: 2323
    Price: $129.99 (Introductory Price of $99.99 per set)
    UMI’s light weight solid motor mounts for the 98-02 4th generation F-Body bolt into existing holes in the engine block eliminating the factory rubber motor mounts. Solid motor mounts are designed to work with the factory K-member, UMI K-member and many other aftermarket K-members that use a factory style pedestal mount. These solid motor mounts are CNC machined from 6061 aluminum, nicely sanded and finished with a hard anodize to prevent corrosion. These aluminum motor mounts weigh half the weight as the factory motor mounts saving 3lbs of total weight. Motor mounts are simply bolted in to place using existing hardware, no modifications required
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    Those look nice.
    Join the PHK @ thephk.org Sommer86@6LE's Avatar
    Studio City, CA
    Any idea on noise or vibrations? I've debated solid mounts but those were always questions I had.
    Join the PHK
    2009 LS1.com Calendar Car
    Fresno Ca
    LPM
    2002 Z28 Camaro
    They look great! How about sending me a set for my B-Day UMI? Feb 16th
    Any pics of them installed?
    Pa
    Thanks everyone.
    These are solid mounts so there will be a firmer ride and possible vibrations so this definitely needs considered before running these.
    I will have some more pictures in a week or so. I will also have a better product picture, the picture above is plain aluminum with out the clear finish and the first set off the machine. The others have less marks in them.
    Thanks!
    Ryan
    Junior Member WS.SIX's Avatar
    Dec 2009
    Colorado
    2000 A4 WS.6
    wish i didnt buy the full solid motor mounts already
    Aug 2009
    NC
    midnight blue
    2000 trans am
    Quote Originally Posted by Sommer86@6LE View Post
    I was wondering the same thing, do you have more body twist with these solid mounts? I mean I have ya'll's SFC just wondering?
    Member 20ws6speed01's Avatar
    Jun 2009
    Winston,OR
    blue
    2001 WS6
    Quote Originally Posted by WS.SIX View Post
    Thats what i was thinking...I just installed a cam and wow she shakes alot..just think if it was solid...
    Damn nice looking mounts. Cannot recall who, but I know at least one member on here is running solid mounts on the street and says it is not bad at all.
    Orlando, FL
    Mean Black
    I will think that with solid mounts you will get more vibration since there is no rubber to absorb vibrations... I'm fixing to do prothane mounts and im wondering about vibrations too. Oh well they are alot cheaper than stock ones...
    Member qwik219d9's Avatar
    Sep 2008
    Atlanta, GA,Ft.Walton Bch,FL
    Blog Entries
    1
    99 ws6
    do LTs have to be removed to install new motor mounts?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Solid mounts always elicit drama from internet racers that have never used them. They were one of the best mods made to my turbo T/A. There was the tiniest bit of vibration added (only at one RPM spot and poly mounts do the same) but the difference in feel is incredible.
    Jun 2009
    Winston,OR
    blue
    2001 WS6
    Would U install them on a DD ???
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    how hard is it to install these, or any mounts for that matter?
    Is this a jack and some wrenches job, or more like pulling a motor
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by 20ws6speed01 View Post
    It depends on the setup. There are certainly mods that hurt driveability much more.
  1. Solid Motor Mounts
    By Z28boy2000 in forum External Engine
    Last Post: 01-16-2012, 09:29 PM
  2. New Product! 98-02 LSX Solid Aluminum Motor Mounts from UMI
    By UMI Performance in forum Suspension and Handling
    Last Post: 02-05-2011, 04:24 PM
  3. solid motor mounts?
    By SHovV in forum General Help
    Last Post: 05-30-2009, 04:34 PM
  4. solid motor mounts
    Last Post: 05-02-2009, 07:32 AM
  5. Solid Motor Mounts
    By ls1camino in forum External Engine
    Last Post: 09-09-2008, 01:44 PM
