Results 1 to 3 of 3
02-03-2011, 05:05 AM #1Member
- Dec 2005
- Pa
New Product! 98-02 LSX Solid Aluminum Motor Mounts from UMI
Solid Aluminum Motor Mounts for the 98-02 Camaro/Firebird LSX Engines
Part #: 2323
Price: $129.99 (Introductory Price of $99.99 per set)
UMI’s light weight solid motor mounts for the 98-02 4th generation F-Body bolt into existing holes in the engine block eliminating the factory rubber motor mounts. Solid motor mounts are designed to work with the factory K-member, UMI K-member and many other aftermarket K-members that use a factory style pedestal mount. These solid motor mounts are CNC machined from 6061 aluminum, nicely sanded and finished with a hard anodize to prevent corrosion. These aluminum motor mounts weigh half the weight as the factory motor mounts saving 3lbs of total weight. Motor mounts are simply bolted in to place using existing hardware, no modifications required
02-03-2011, 09:42 AM #2
Looks awesome, i will definately have my eyes set on these in the future
02-05-2011, 04:24 PM #3
will these rattle you're teeth out? sry for the noob question
Solid Motor Mounts
By Z28boy2000 in forum External EngineReplies: 2Last Post: 01-16-2012, 09:29 PM -
By UMI Performance in forum External EngineReplies: 14Last Post: 02-08-2011, 10:58 PM -
solid motor mounts?
By SHovV in forum General HelpReplies: 12Last Post: 05-30-2009, 04:34 PM -
solid motor mounts
By SHovV in forum General HelpReplies: 4Last Post: 05-02-2009, 07:32 AM -
Solid Motor Mounts
By ls1camino in forum External EngineReplies: 7Last Post: 09-09-2008, 01:44 PM
