Results 1 to 20 of 50
Thread: Cooling system flush question
01-22-2011, 08:56 AM #1
Ok so I got everything I need for the flush that I'm going to do this week. I'm doing it the way that Pajeff02 told me. Drain the radiator, pop the tstat out off the housing and put the housing back. pull the drain plugs on the block. Put plugs back and refill with water. Run for like a few minutes. When is cool enough drain everything again and repeat process until the water comes out clean. Put Tstat back and refill. I'm removing the hose that comes out of the block (the TB bypass one) to make sure I get rid of any air.
I have a few questions before I start. Does this work for sealing the drain plugs after I'm done with the flush? I think is paste teflon. Or should I just use regular teflon tape?
Is it okay to use the prediluted stuff to fill the system? Is 2 gallons enough to top it off?
I'm guessing is a good idea to cover the alternator when im draining the plug next it. Any other suggestions? Thanks.Last edited by JayTA98; 01-31-2011 at 06:47 PM.
01-22-2011, 10:28 AM #2
The thread paste should work fine. Remember, that when you use it the paste also acts as a thread lubricant. Be careful not to overtighten the fitting and strip something in the process. You are playing with brass and aluminum -- both soft metals.
I think it's a waste to buy the pre-mix as the price simply does not justify it. You are basically buying a half gallon of coolant and water for about the same price as a gallon of coolant. You will also want to flush out your coolant overflow tank as well.
01-22-2011, 11:01 AM #3
It's just hard to find distelled water. Where do you get it at? I have to take out the overflow tank to clean it right? Thanks for the quick reply.
01-22-2011, 11:27 AM #4
01-22-2011, 11:40 AM #5
^^ This. The overflow tank is easy to pull. I dumped it, partially filled it with tap water, and then shook the hell out of it. Did this several times to remove as much of the gunk as I could.
01-22-2011, 01:00 PM #6
01-22-2011, 02:45 PM #7
It may be in the same shelf area, but you don't want 'drinking water'.
Should be marked specifically 'distilled water'.
Might be right next to it, ..., might also be in the laundry/cleaning supplies area.
If you've already bought two gallons of the pre-mixed, ..., how much fuel/time are you going to waste going back for something different?!?
Just use it, ...
01-23-2011, 06:19 AM #8
01-23-2011, 06:37 AM #9
01-23-2011, 06:47 AM #10
01-23-2011, 08:18 AM #11
I am gonna be doing this soon. I am subscribed. And what thermostat and gasket ? do I need. I hear everyone talking about 160* stats. I live in AZ. And I am gonna have frost tune it this summer. Help me out here? And can't you just let tap water sit for 24 hours and it is distilled?
01-23-2011, 08:38 AM #12Impounded
- Apr 2006
- park bench
- gmcheviac
01-23-2011, 10:47 AM #13
Anything other than the stock thermostat requires the fans to be reprogrammed for it to have any real effect. I also went with a 180 degree thermostat in ours. On the scanner, the engine stays between 183 and 194 degrees for the most part. Once, on a real hot day with the AC blazing in standstill traffic, I saw a max of 205.
01-24-2011, 03:37 AM #14
01-24-2011, 03:42 AM #15
The green vs. orange issue has been debated to death on here. Both have staunch advocates. In reality, the concerns with Dexcool were from when it was first introduced and these have long since been remedied. I am comfortable putting either coolant in our vehicles. Just one cardinal rule -- DO NOT MIX THEM. If you are changing from one to the other, you need to perform a thorough flushing of the entire cooling system. This includes the overflow bottle, heater core and block drains.
01-24-2011, 04:03 AM #16
So if im changing to green stuff is better to get the 50/50 diluted stuff? or if i do the flush like you recommend can i then use regular green stuff with distelled water? I'm trying to get away from dexcool but if its going to cause issues of mixing then ill stick with dexcool. I change my coolant every year.
I'm planning on doing this today. So let me know plz. Also should I change the radiator hoses? I mean they look fine but I know they are old.
01-24-2011, 04:17 AM #17Grand Imperial Wizard
- Retired Outlaw Sum Bitch
If you are going to change coolants. Flush the crap out of your cooling system. Make damn sure not one drop of the "other" coolant remains. Mixing different types of coolants is a bad bad thing as they have totally different add packs/chemicals and they do not play well together at all. My recommendation is stay with DexCool as it is formulated per GM engineers specs specific and you gain nothing with going green or yellow. Nothing. I have run DexCool for a kazillion miles with no negative effects. I maintain my rides cooling systems and am on top of any leaks or defective system componenets....as we all should.
Be proactive with the hoses and belts. Why wait until your out in the middle of HooterVille and one blows/breaks. Be proactive.
As mentioned.....if you adjust your thermostat to other "open at" temp ranges....adjust your fans also.
01-24-2011, 04:31 AM #18
The tsat was changed with a 180 like 6 months ago. I will get the gallon of dexcool to be on the safe side. I can't agree more with been proactive I just heard of autoparts hoses been crap and cracking easier than stock ones. But I always maintain my stuff. Since im draining all this stuff out I figure why go thru all that when the hose breaks in a week or so. that will be extra work. Ill go get them today from auto zone. thanks for the advise Sarge.
01-24-2011, 06:01 AM #19
Okay the only stuff I find is prestone dexcool approved stuff. Will that work?
01-24-2011, 06:39 AM #20
I think that is what I ended up with -- it was marked "GM Approved" as I recall. Interestingly, our local GM dealership did not have any Dexcool in stock and would not order it unless I purchased the entire case.
DIY cooling sytem flush
By JayTA98 in forum General HelpReplies: 39Last Post: 10-22-2020, 01:04 PM -
Cooling system (please help)
By Supersport0126 in forum External EngineReplies: 2Last Post: 03-18-2012, 07:43 AM -
Question: Cooling system
By travs98ls1 in forum Firebird / WS6Replies: 2Last Post: 07-01-2010, 07:37 PM -
A/c system flush?
By Bigsword4 in forum General HelpReplies: 14Last Post: 07-10-2009, 07:50 AM -
Help: Cooling system issues
By Hawk23 in forum Firebird / WS6Replies: 3Last Post: 04-25-2008, 06:38 PM
