Results 1 to 3 of 3
Thread: Cooling system (please help)
03-18-2012, 07:02 AM #1Member
- Aug 2011
- pittsburgh,pa
navy blue- 1998 camaro ss
Just put in a new alum. Rad. And I been having a problem with oil (motor or p/s) mixing with the coolant! Can someone tell me if I can just remove the p/s cooler lines and just splice them together? My coolant reservoir also gets all mucky, but the engine oil is fine! Is this most likely the p/s cooler? And is it ok to bypass it? Thanks
03-18-2012, 07:09 AM #2
You can bypass it or replace it with a small tube and fin style cooler. I mounted a cooler in front of my steering rack and was able to use the stock hoses.
03-18-2012, 07:43 AM #3Member
- Aug 2011
- pittsburgh,pa
Is the p/s mixing with the coolant a common problem with these?
LS1/LT1 cooling system corrosion.
By WS6ADDICT in forum External EngineReplies: 4Last Post: 02-27-2011, 12:53 PM -
Question: Cooling system
By travs98ls1 in forum Firebird / WS6Replies: 2Last Post: 07-01-2010, 07:37 PM -
2003 Silverado cooling system
By red99ws6 in forum General HelpReplies: 4Last Post: 01-30-2009, 04:37 PM -
Help: Cooling system issues
By Hawk23 in forum Firebird / WS6Replies: 3Last Post: 04-25-2008, 06:38 PM -
Heating / cooling system help needed!
By Fastcar in forum General HelpReplies: 1Last Post: 06-15-2007, 12:16 PM
