02-18-2011, 06:08 PM #1Junior Member
- Sep 2005
- Fairview OK.
yellow- 2002 CETA T/A
LS1/LT1 cooling system corrosion.
LS1/LT1 cooling system corrosion. Our cars are getting to the age that this is about to be a big issue. I've kept mine flushed every 3 years with the drain the radiator, refill and run til the thermostat opens then repeat method.(ls1's, NOT lt1's!!)
I've read up and no-rosion additive once a year is the deal. Go to no-rosion.com and click on technical. Sure beats heater core replacement & head gaskets down the road. I worry a little cause my cars snooze all winter. These people have alot of knowledge about coolant.
5 gallon pails are the cheapest & split it up with 4 friends.
02-21-2011, 09:09 PM #2
Don't know if you are pitching a additive for someone or asking a question
It is true that Dex Cool tends to go to shit after some time but if your flushing your car out in those intervals then you should be fine without any type of additive. LS1's are great motors that just need the basic maintenance to stay running strong for tons of miles.┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
02-24-2011, 11:07 PM #3
I had a huge problem with a '97 Formula's cooling system with corrosion and overheating. I flushed it multiple times, even had a new radiator installed, and still had coolant overflows and imbalances in temperatures. Wondering if this is more with the LT1 rather than the LS1? Hoping I don't have the same issues with my Camaro.
02-25-2011, 07:50 AM #4Junior Member
- Sep 2005
- Fairview OK.
Just providing information on norosions site. Their product is good, but the info he has on his site on Dexcool is only a fraction of what these people know about green and Dex. People don't have any idea about the chemistry involved. For instance, a car with Dex has a protective film built up on the metal walls. Using green does no good after a car is run with Dex for a short time. It's a long story... Your info is very true on LS1's BLACKSS01.
02-27-2011, 12:53 PM #5
Over time any cooling system becomes corrosive. As long as you flush the cooling system periodically an additive is not needed.
Cooling system (please help)
By Supersport0126 in forum External EngineReplies: 2Last Post: 03-18-2012, 07:43 AM -
Question: Cooling system
By travs98ls1 in forum Firebird / WS6Replies: 2Last Post: 07-01-2010, 07:37 PM -
2003 Silverado cooling system
By red99ws6 in forum General HelpReplies: 4Last Post: 01-30-2009, 04:37 PM -
Help: Cooling system issues
By Hawk23 in forum Firebird / WS6Replies: 3Last Post: 04-25-2008, 06:38 PM
