Results 1 to 15 of 15
    Charlotte, NC
    2000 WS6
    A/c system flush?
    Im about to replace the entire a/c system on my car with a new compressor, drier, condenser, and orifice tube. Since every thing is new do I still have to flush the system? And how should I go about it? Ive heard its not good to flush the compressor or the condenser.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I guess the only things left to flush would be the lines/hoses and the evap core. There isn't any need to flush the new components and definitely not the compressor. There also usually isn't any need to flush the system unless the compressor eat itself up and sent metal trash throughout the system.
    By "flush" do you mean evacuating the system under prolonged vacuum? I have never heard of flushing the AC system before.
    Charlotte, NC
    2000 WS6
    thats what I thought and Im pretty sure the compressor didnt do any damage because I stopped using it. I just wanted to make sure since this is my first time dealing with the a/c system.
    thanks
    LINGER LONGERRR DUBB's Avatar
    BC,CANADA
    02 M6 Formula
    ]There also usually isn't any need to flush the system unless the compressor eat itself up and sent metal trash throughout the system.
    exactly
    im no auto a/c guy but you should be alright as long as the system/oil isnt contaminated which would pretty much only be if you had a compressor burnout.
    Charlotte, NC
    2000 WS6
    Do any of you know where I can find how much oil needs to be added to the compressor? I looked in the owners manual but it just says look under the hood and the label under the hood tells what kind of oil but not how much.
    Madison, WI
    2001 Silverado Z71
    like 2 shot glasses worth
    The spec in the factory service manual for an '02 is 3 ounces. I assume it would be the same for yours.
    Madison, WI
    2001 Silverado Z71
    There are AC flushing liquids that can be pressure injected through the ac lines. That way I've done it is with the compressor out of the car, I back flush the lines from the orfice tube area back to the compressor. That'll help get the metal debris out.
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Are you sure? I keep seeing capacities of 9oz PAG & 24oz of refrigerant for a fresh system.
    Quote Originally Posted by rbob93 View Post
    I will check again when I get back home -- at the office now. The manual listed PAG refills from 1 to 3 ounces, depending upon what component was being replaced.
    Charlotte, NC
    2000 WS6
    Does anyone know orifice tube is located?
    Jun 2009
    tinley park il
    99 trans am ws6 ram air
    its in the evaparator inlet tube
    Junior Member FUEL009's Avatar
    Jul 2009
    Houston
    Gold
    1999 , Trans am
    inlet tube ?
    Charlotte, NC
    2000 WS6
    thanks, almost done!
  1. Cooling system flush question
    By JayTA98 in forum General Help
    Last Post: 07-23-2011, 11:32 AM
  2. Transmission Flush
    By pajeff02 in forum Automatic Transmission
    Last Post: 05-12-2011, 08:06 AM
  3. Flush 411
    By Sarge in forum Automatic Transmission
    Last Post: 12-27-2010, 02:25 PM
  4. Coolant flush
    By Z28_Driver in forum General Help
    Last Post: 03-21-2010, 04:50 AM
  5. Coolant Flush
    By samson_420 in forum General Help
    Last Post: 10-28-2007, 08:21 AM
