01-12-2011, 07:48 PM #1
if i need a new rear main seal...
what else should i look at getting done?? my mechanic is telling me it would be a good time to get a new clutch... i have high mileage, 150k, on the original clutch. other than a little bit of lazy pedal when it cold outside, i haven't noticed any clutch problems..
if so, is there a specific clutch package i should look for? i don't need high perf, just something adequate for daily driving and good quality? is the OEM good enough?
01-13-2011, 01:38 AM #2
I'd look through these guys to get the best price
http://www.ls1.com/forums/sponsor.php
An ls-7 clutch kit is a nice cheap upgrade. If the original lasted you this long I don't see the need to go spending the money on aftermarket clutches.
01-13-2011, 03:01 AM #3
Unless there is something different about the '99 -- the factory service manual recommends against machining the flywheel. It has a tapered surface and should be replaced.
01-13-2011, 04:49 AM #4O U 8 1 2
- Nov 1999
- over here...
replace the master and slave cyl... new cluthch and fly wheel... might as well get a new throwout bearing as well...
01-13-2011, 05:15 AM #5
x 1000
01-13-2011, 07:18 AM #6
thanks for the replys! is there anything transmission-wise (it's a manual) i should have looked at? at the least i'd ask them to change the fluid..
01-13-2011, 07:24 AM #7
I'd change the oil in the tranny if it hasn't been done in a while. It's easier to do while it's laying on the tranny jack
Simple drain and refill, doesn't cost much.
I agree with the others, after pulling all that down for a rear main, with that many miles, I'd do it all, clutch/pressure plate/flywheel/throwout bearing/slave cylinder/ that way you can be assured it's all buttoned back up for a long time. While you're at it, I'd prefer to do a master cylinder too.
It's going to set you back a good chunk of money to do it all,,,,but at this point I call it preventative maintainance, do it before it leaves you stranded somewhere.
Rear Main seal
By miguelr1988 in forum General HelpReplies: 1Last Post: 09-20-2012, 10:49 AM -
rear main seal help
By Leeroyws6 in forum External EngineReplies: 5Last Post: 10-28-2010, 08:01 AM -
Question: Rear Main Seal
By SMWS6TA in forum General HelpReplies: 10Last Post: 08-01-2010, 06:07 AM -
Rear main seal?
By yellowv in forum General HelpReplies: 6Last Post: 08-19-2009, 02:49 AM -
rear main seal
By 00z28bubba in forum General HelpReplies: 7Last Post: 11-20-2008, 10:35 PM
