    Member Leeroyws6's Avatar
    Feb 2010
    fort worth
    2000 trans am ws6 a4
    rear main seal help
    trannys got to come back out.can someone tell me how to change the rear main seal?does the oil pan have to come off?also when i started the car after it sat for about 3 weeks,the water pump seems to be leaking right above the crank pully.does the water pump have to be replaced or just the gasket?please help thanks
    Senior Member
    texas
    2000 formula
    considering what a PITA it is to do the rear seal i am going to drop the engine out to do mine......i have many gaskets to change out besides that 1 and it would be ALOT easier not to fight cramped spaces.....unless you can see the gasket leaking i would bet its the pump not gaskets
    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    Rear main is a breeze with the tranny out- you don't have to pull the pan. Pull the two bolts from the bottom and then pull the cover off that the rear main fits into (can't remember what it's called.) Get the Fel-Pro gasket kit- same price as the GM and it comes with both gaskets. Pop the rear main out from the inside of the cover and then use a rubber mallet to knock the new one back in. Seriously easy.
    2000 Pontiac Firehawk #0041 of 742
    Feb 2010
    fort worth
    i think that piece is called the adapter that the seal fits into.i hear if i get it out i wont be able to get it back in...
    Aug 2009
    Memphis, TN
    Bright Red
    Took mine out and it went right back in. Wasn't a problem at all.
    Arizona
    Easy to change. I've done mine a couple of times. Just make sure you put the seal in facing the correct direction. I bought mine from GM and it came with instructions showing which way the seal should be facing.
    Funny though, GM replaced it once under warranty and they put it in backwards. Needless to say it leaked. I ended up tearing it back down and replacing it myself.
    There is also a process mentioned (and a special tool made) to center the seal on the crankshaft, since that rear plate moves around a bit. Take your time and it's pretty straight forward.
  1. Rear Main seal
    By miguelr1988 in forum General Help
    Last Post: 09-20-2012, 10:49 AM
  2. if i need a new rear main seal...
    By wileyCoyote in forum General Help
    Last Post: 01-13-2011, 07:24 AM
  3. Question: Rear Main Seal
    By SMWS6TA in forum General Help
    Last Post: 08-01-2010, 06:07 AM
  4. Rear main seal?
    By yellowv in forum General Help
    Last Post: 08-19-2009, 02:49 AM
  5. rear main seal
    By 00z28bubba in forum General Help
    Last Post: 11-20-2008, 10:35 PM
